Turbo 240 or 300
Ramian17":1zbir4xi said:
Cool so you like the drawings ?
Yep like the drawings.
It looks like the turbo/header flange is about 45 degrees with the front of the engine (Or the side of the engine)
Is that correct?
No I don't think it will be that much of an angle but it will definitely be at an angle. Just to help with flow of everything. Is that alright?
Ah I see and I like it. I think that my arm is still going to need to be bent to move it over to almost perfect center in the front of the motor. Thus putting the flange at a small angle is that ok? If I don't move it over and it's a straight arm like you are showing I think that i will have clearance issues with the exhaust outlet and the dog house. When you move it over to center it makes it so that it gets better flow from the header of its at an angle.
What you think?
Not a problem. You can bend the bracket right after it passes the pulley.
Then modify the gusset plate to follow the top of the bent bracket.
Yeah side view will have to wait untill tomorrow. I already took off sorry. The radiator and the intercooler are both going to be under the floor behind the grill. In the first pic of that last post you can see the bottom of the radiator and the fan under the turbo. It's that black thing lol. What's the secret to these double slip couplings on the collectors my welder isn't familiar with them. Also how exactly level does this turbo need to be?
The only turbocharger orientation that is important is the center section.
It is best if the oil feed is on top and the oil return is facing down.
The double slip collectors DO NOT get welded. The primary pipes simply slide into place and are allowed to contract and expand and move around without having welds to stress and eventually fail.
See half way down the page.
http://www.burnsstainless.com/technolog ... aders.aspx
Crazy so that little piece doesn't get welded to the collector, or the pipe coming up to the collector? The pipes just slip into that little sleeve? Does the oil feed need to be perfectly vertical it is definitely coming in from the top but it is at a little angle maybe 15° to 20°. Which then makes it so the coolant isn't flowing completely level across the turbo. Is all that ok? I was told that for longevity of turbo you want the shaft horizontal to the ground? How exact should that be?Also I am about to order the fuel pump, fuel regulator and the intercooler. Are these all still correct for this set up? Or do I want to max out inter cooler? I could definitely go taller and could go to right round 30 inches total width.
https://www.summitracing.com/parts/aei-18689/overview/
https://www.summitracing.com/parts/aei-13129/overview/
https://www.ebay.com/itm/Rev9-V-Mount-T ... gz&vxp=mtr
The oil return can be at a small angle. The object is to allow gravity to drain the oil out of the center bearing area.
I'm not sure how important it is to have the turbo shaft parallel with the ground with ceramic bearings that also provide thrust support.
Fuel pump and regulator are good.
Go for the biggest intercooler possible.
Got the side view. So can you see how when my hands aren't holding it the turbo isn't level aka in the correct position. Because of the heims it still doesn't hang perfect. It takes a couple pounds up on the compressor side is the easiest way to level it, Or like in the pic you can push up opposite of the flange too. So Should i build the header next to support it? I was also thinking I could build the intake to the compressor side out of aluminium and mount it to the motor on the other side before I build the header? The aluminium mount wouldn't have any heims but all in all would not be very stiff then I was thinking of building the aluminium tubing to the intercooler. The intercooler would be hard mounted to the frame not the motor so the tubing would have to be somewhat flexible but also might almost be stiff enough to support the turbo so it hangs more level. You could even have the exhaust put on and hung cause it would be mounted to the frame with thick pieces of rubber also providing support but still very flexible. Do all of this before I build the header? I'm just not familiar with the double slip joints and how well this header is going to hold the Turbo. Or just go for header lol? Thanks for reading all this you guys and for all your help !!!!!! I couldn't of done it without you. There is just so many unknowns and so many start over/redo moments that I'd like to not mess this header thing up.
https://www.dropbox.com/s/w5q5mh7iqr01y ... 7.jpg?dl=0
https://www.dropbox.com/s/1xyqkjyku83ks ... 4.jpg?dl=0
https://www.dropbox.com/s/90lmdz9mca706 ... 5.jpg?dl=0
https://www.dropbox.com/s/l9qis0yh51afm ... 2.jpg?dl=0
https://www.dropbox.com/s/wyglbhl7xbn37 ... 4.jpg?dl=0
Header next.
The way it should work is, the header will hold the turbo upright and level especially with six pipes attached to the collector.
The six primary pipes will approach the collector at different angles so the collector cannot be removed from the pipes or move period even with slip joints.
The hanger with the Heims only has to take the weight of the turbo off the end of the header and nothing else.
To help with flex you use silicone rubber tubing between the aluminum tubing coming from the frame mounted intercooler and the engine mounted turbo.
They come in straight, elbow, reducer and other shapes and sizes.
Example: http://www.turbosmartdirect.com/Product ... cone-Hose/
Ok so I got the exhaust mandrel bends for the turbo exhaust outlet. Now!!?!??? I think the turbo is where it is going to live and I hope you guys like these angles? Just want to make sure that the bends around the water pump pulley aren't to extreme? They will be in the two inch pipe after the six have consolidated to two. I think they are fine and have plus they kinda have to be. I guess just another question before we start cutting these stainless. Cause if this looks good to go tomorrow we go forward with header!!!!!
What do you think about the bend around the pulley and then there is also a little bend going into the turbo?
If that's where the turbo needs to be to get all the ins and outs to work then go for it.
The 2" tubing bends around the pulley aren't very much and will be OK.
