Who has the Offenhauser 3x1 aluminum intake?
Old man Dave
Post #1 by Old man Dave » Wed Jan 10, 2018 11:19 pm
Couldn't find any posts about this. Does this thing work? Any problems installing or using? Thanks for any info.
chad
Re: Who has the Offenhauser 3x1 aluminum intake?
Post #2 by chad » Thu Jan 11, 2018 1:20 am
Welcome! o.m.Dave !
There's many threads on this site. Some have DYI alternatives, some the original (there's at least 2 for the ford6), others one alternate co.
R U sure U don't mean "cast alu removable" intake (a la the Oz style)? Isn't the Offy iron? That's sold thru Summit'n others (ck our "4 sale" forum. I've seen um there too).
Old man Dave
Post #3 by Old man Dave » Thu Jan 11, 2018 2:27 am
There is one for sale on ebay, and it appears to be aluminum. Is there an easy way to search old posts by topic? Obviously I'm new here.
cr_bobcat
Post #4 by cr_bobcat » Thu Jan 11, 2018 7:00 am
It's an aluminum plate that mounts over the log. I would recommend VintageInlines. This way you are sure to get all the mounting hardware and the linkages.
https://www.vintageinlines.com/product-page/offenhauser-triple-manifold-adapter-1960-1968
chad
Post #5 by chad » Thu Jan 11, 2018 9:35 am
Old man Dave wrote:... Is there an easy way to search old posts by topic? Obviously I'm new here.
At the top right of each screen we have a search function...
powerband
FSP Moderator
Post #6 by powerband » Thu Jan 11, 2018 9:46 am
You didn't mention if you have a 'small block' or 'big block' six. For the integral intake 144/170/200/250, there are basically two different versions of the Offenhauser 3X1 aluminum adapter. The two Offy' versions fit (@ 60-67 vs @ 68-82) all small block six heads which are interchangeable between all the small blocks 144 to 250 cid but have different shape of the integral intake 'log'
Edelbrock also mfg'd a tri-power adapter for the early intake version.
If you search on offy or offenhauser you can find many postings on building and tuning this modification.
here's a post/thread on the basics.
viewtopic.php?f=1&t=76149&p=586466&hilit=hours#p586466
viewtopic.php?f=1&t=59024&p=453190&hilit=offy#p453190
Old man Dave
Post #7 by Old man Dave » Thu Jan 11, 2018 3:04 pm
Sorry I didn't mention the engine size. I posted this in the small six section and assumed that would cover it. I am talking about a 200.
cr_bobcat
Post #8 by cr_bobcat » Thu Jan 11, 2018 4:39 pm
That covers it. As mentioned earlier though, there are different castings of the head. You'll need a different setup based upon what head you have. In 1969, the log got bigger and wider, so you would need the Offy manifold designed to fit the smaller diameter log. I would recommend calling Matt at VintageInlines and have your head casting number handy. This way you get the part that fits the first time. :beer:
chad
buyin the tri-power
Post #9 by chad » Thu Jan 11, 2018 5:30 pm
Old man Dave wrote:Sorry I didn't mention the engine size. I posted this in the small six section and assumed that would cover it. I am talking about a 200.
Matt (at Vintage Inlines dot com)is one of the carriers for the ford6 performance Handbook. U may wanna get 1 of those to get up to speed on these i6 motors.
(U got 1 of the 6 models, Falcon or Thriftpower by name, manufactured over 36 yrs, bridgin into the EFIs thru the '96 final yr).
:nod:
It shows the tripower set up w/linkage/carbs/throttle.
What carbs will you use?
Old man Dave
Re: buyin the tri-power
Post #10 by Old man Dave » Thu Jan 11, 2018 9:23 pm
What carbs would you recommend?
drag-200stang
Post #11 by drag-200stang » Thu Jan 11, 2018 9:55 pm
At this point we know that your name is Dave and you are an old man that has a 200, :D but we do not know much about your car..what year is the head, stick , auto, rear gear, cam ,etc.. how do you plan on using the car..Your location would help, I am in Michigan in the mitten, there is one in a valley and a swamp. :wink:
66 Mustang Coupe
200 turbo w/lenco 4-spd
Went 9's when 10's was fast.
chad
Post #12 by chad » Fri Jan 12, 2018 12:12 am
Old man Dave wrote:What carbs would you recommend?
Like drag-stang sez (implied) depends on whaja planning. But...
on a rd car (not mine, C avatar) I like lookin @ those ol glass bowls (is it Holly 1940 or 1904? there's both so I get confused. My LD dont help none neither!).
:oops:
Old man Dave
Post #13 by Old man Dave » Fri Jan 12, 2018 1:15 pm
OK...I'm not much of a typist, so I try to keep stuff short. The '56 is project #3 on my list of stuff to do. It needs pretty much everything, but is surprisingly rust-free. I would just like to get it on the road and eventually make it my daily driver. Don't have the money or ambition to restore it to stock. The tri-power just sounds like something cool to try, along with headers. Don't have any plans to go crazy building this little engine. Just want it to look and sound good. Thanks for your interest. BTW, what carbs do guys usually run on this setup? I have two of the stock carbs...They worth re-using?
jdn21758
Post #14 by jdn21758 » Fri Jan 12, 2018 1:28 pm
hallo dave i have used carter YF carbs,,
watch on you tube my channel if you like search my name
jan douwe noordenbos there some films from my triple carb
mustang.
greeeetzz,,, jan douwe noordenbos from the Netherlands.
Old man Dave
Post #15 by Old man Dave » Fri Jan 12, 2018 2:36 pm
Thanks for the info. Enjoyed the videos.
Old man Dave
Post #16 by Old man Dave » Fri Jan 12, 2018 5:00 pm
BTW, this is the first time I've ever messed with a Ford six. My other two projects have BBC's in them. And, I have managed to end up with two 200's - One is a '66 and the other is a '78. Just from eyeballing it, I think the '78 has a large log manifold. Can anyone confirm or refute that? Thanks again.
Post #17 by bubba22349 » Fri Jan 12, 2018 6:41 pm
:beer: congrats, yes if the 1978 still has the stock head on it then yes it's the large log look for a D8 prefix on the log. This would use an Offy 3 X 1V manifold number 5970, (see below link). Good luck :thumbup: :nod:
https://www.speedwaymotors.com/Offenhau ... gJ8SvD_BwE
Old man Dave
Post #18 by Old man Dave » Fri Jan 12, 2018 8:39 pm
Thank you!
jdn21758
Post #19 by jdn21758 » Sun Jan 14, 2018 5:51 am
flat log after 68
round log before 68
greetzz JD
jdn21758
Post #20 by jdn21758 » Sun Jan 14, 2018 6:24 am
this is my engine 200 cui with a flat log after 68.
greetz,,JD
jdn21758
Post #21 by jdn21758 » Sun Jan 14, 2018 6:38 am
this is the Original 68 engine 200 cui my next project with a round log.
greetz,,JD.
Old man Dave
Post #22 by Old man Dave » Sun Jan 14, 2018 12:39 pm
Sweet! Thanks for the pic's.
JackFish
Post #23 by JackFish » Sun Jan 14, 2018 2:22 pm
Wondering if it might be possible to rig on of these up with a cable throttle, as I have a fox-body?
Yup, I bought another one.
1996 Chevy Caprice 9C1 (3)
1999 Dodge Ram 2500
vssman
Post #24 by vssman » Sun Jan 14, 2018 6:52 pm
JackFish wrote:Wondering if it might be possible to rig on of these up with a cable throttle, as I have a fox-body?
Yes you can. I changed my mechanical linkage pedal to a cable throttle pedal on my 63 Falcon. The outer carbs are still activated via the rods off of the center carb.
63 Falcon 'vert running a 68 200CID Tri carb and a few other goodies
powerband
FSP Moderator
Post #25 by powerband » Sun Jan 14, 2018 7:02 pm
original Offy linkage mated to Maverick six pedal and over VC cable mount / Holley 1904's.
haev fun
JackFish
Post #26 by JackFish » Mon Jan 15, 2018 7:18 pm
Aah, very nice, yah that might work for me. :idea:
1999 Dodge Ram 2500
Users browsing this forum: No registered users and 32 guests
