Studs to mount carb to short on 200 6 stock spacer w phenolic. Where to get longer studs?
reweb67
Car is a 1967 Mustang.
I have the stock spacer that goes on a 200 six. The one that supports the throttle linkage and has the area where the heater hose will run through it. I'm adding a phenolic spacer and need the studs to be 1/2 inch longer. I was able to remove the current studs no problem. Anyone know where to get longer ones? Thanks for any help!
Howdy
I changed my studs, i got them at the local hardware store. Its a more specialized place called Tacoma Screw.
Good luck,
Ryan
