Post #2 by TurboBronco » Mon Mar 05, 2018 11:02 am
Installed new main bearings:
After installing the main bearings and torquing the caps to 65 foot lbs, we checked bearing clearances with Plastigage and got .002 on all but one journal and got about .0018 on it. Clearance tolerance is .0009-.0028.
Next, installed rings on the pistons and set the ring gap at .018 on the top ring and .020 on the second ring. Sealed Power recommends .016-.018 first ring and .020-.022 second ring.
Speed Pro Piston Ring Gap Info LinkInstalled pistons in the bores:
Installed rod bearings and checked rod bearing clearance. Rod clearances were .0018-.002.
Lubed all bearing surfaces with Permatex Ultra Engine Assembly Lube before torquing them. Very thick and sticky.
Permatex Ultra Engine Assembly LubeMains and Rods all torqued down:
New Oil Pump & Pickup Installed:
TurboBronco on Mon Mar 05, 2018 12:42 pm, edited 4 times in total.
1985 Ford F250 2WD, Bone Stock 300, T18 Four Speed, OEM intake, OEM Exhaust Manifold, Autolite Single Barrel Carb; 2.5" Exhaust from firewall back, Project in Progress!!
