Solid lifter for the 300? From a 302 or a 429?
Lagerhead
Post #1 by Lagerhead » Fri Jul 12, 2019 1:18 pm
With the refresh of my motor I'm switching to a flat tappet solid cam and need bing to know what lifters to order.
Thank in advance for the Input
99.5 F350 lowered air ride strong PSD crew cab swb
48 ford coupe cage old school stock car 12.25 to 1 290 cilford cam, cliford 2x2 with webber 38/38,some cool old stock car headers, 240 head with big valves, bbc roller rockers
pmuller9
Re: Solid lifter for the 300? From a 302 or a 429?
Post #2 by pmuller9 » Fri Jul 12, 2019 3:49 pm
Which solid lifter cam is it?
Did you go with Berry Cam Service?
Lagerhead
Post #3 by Lagerhead » Fri Jul 12, 2019 6:18 pm
Ita a Erson 320° .570 lift 104 center line
Max_Effort
Post #4 by Max_Effort » Fri Jul 12, 2019 6:59 pm
Lagerhead wrote:With the refresh of my motor I'm switching to a flat tappet solid cam and need bing to know what lifters to order.
This is the lifter, these numbers interchange (and yes, they fit 302,429 and many other Ford engines) two I’ve listed have the .015” oiling hole in the lifter face and I’d recommend it.
______________________
Standard replacement:
SBI VL48
Federal Mogul AT2000
Elgin VT-2000
___________________
A bit better:
Top line (hylift-Johnson) A2000,
A2000E with the .015” oiling hole
___________________
The premium lifter is Johnson 5215.
5215OH (with .015” oiling hole)
pmuller9
Post #5 by pmuller9 » Fri Jul 12, 2019 10:21 pm
The cam is using the Erson F320/.355 lobe which will give you .586" valve lift with .017" lash if it is being used with 1.7 ratio BBC roller rockers.
Are you using the SBC 4.911" long valves to accommodate that much valve travel?
Lagerhead
Post #6 by Lagerhead » Sat Jul 13, 2019 7:29 am
The motor dose have sbc valves and thanks for The part numbers I will do the follow you today
pmuller9
Post #7 by pmuller9 » Sat Jul 13, 2019 9:51 am
I'm curious.
If I'm reading this correctly the cam has 284* .050" duration on a tight LSA with at least 68* of overlap. (108 LSA, 104 ICL)
If so that is strictly a drag racing cam.
Is that what you are doing?
Max_Effort
Post #8 by Max_Effort » Sat Jul 13, 2019 10:17 am
pmuller9 wrote:I'm curious.
I was thinking that's a lot of cam and lift, then I read the OP's signature line...
pmuller9
Post #9 by pmuller9 » Sat Jul 13, 2019 10:42 am
Max_Effort wrote:I was thinking that's a lot of cam and lift, then I read the OP's signature line...
I read the signature line also.
The Clifford cam has a 232/232 .050" duration with a couple of 38/38 webbers.
A 284* cam is a big jump.
Users browsing this forum: pmuller9, wallen7 and 15 guests
