67 Mustang Coupe Build
Georgia200
Post #1 by Georgia200 » Mon Feb 04, 2019 11:09 pm
Thought I would start a thread separate from my engine build thread.
I have a 67 200/C4, 3.20 Power Drum Brakes. Rust free, good driver, although I think a cam lob is wiped.
Im swapping in a 250, C4, 8in - 2.79, 5 lug power drum brakes.
While the block is at the machine shop Im working on the 5 lug swap. Fronts are ready to bolt on, the axles are out of the rear end for seals and bearings. I also have a set of 14x6 GT rims that I will put my full wheel covers on with 215-75-14 WWs.
Pics tomorrow.
mustang6
Re: 67 Mustang Coupe Build
Post #2 by mustang6 » Tue Feb 05, 2019 3:40 am
Sounds like a nice build.
Scott
Georgia200
Post #3 by Georgia200 » Wed Feb 06, 2019 12:00 am
Garage is getting busy. 8in for my 67, 8.8 out of my 97 Cobra, brakes, wheels, bikes, wifes car.
I need to get some things completed before the block comes back.
Georgia200
Post #4 by Georgia200 » Fri Feb 08, 2019 3:28 pm
Todays progress:
Dropped the wheels off to have the new tires installed.
Dropped the rear brake backing plates off to have the bosses where the shoes ride repaired. Three of them had grooves.
Dropped the axles off to have new bearings pressed on.
Bought all the gaskets and seals I need to install axles and brakes.
Primed axle housing.
Edit: Gave the new to me front drums a good once over, didnt like what I saw, so ordered new bearings, shoes, cylinders, already have new hoses and everything else looks good. Going with 2.5 vice 2.25 shoes, looks like there is room for them.
Georgia200
Post #5 by Georgia200 » Sat Feb 09, 2019 10:13 pm
Ever so closer
Matthew68
Post #6 by Matthew68 » Wed Feb 13, 2019 8:14 am
Great progress! Keep it coming.
1968 Mustang Coupe 200ci - Pertronix + Coil
Gulfstream Aqua - Interior + Exterior
Georgia200
Post #7 by Georgia200 » Thu Feb 14, 2019 10:46 pm
Sorted some issues out this week:
My research shows that the 1967 200/C4 u-joint is the same as the 289 u-joint. I think my driveshaft will bolt up to the 8in yoke without a u-joint change.
I couldnt ID the front wheel bearings, so I ordered new bearings and seals for the hubs. When the spindles changed in 70, they used different bearings. Any year hubs work as long as you use the correct race and bearing for your spindle diameter.
I planned on bolting up the front brakes as I bought them, but once I gave them a good lookover, I tore them down. All Im keeping is the drums, backing plates and hubs, everything else is new. BTW: 2.5in shoes will not fit the 2.25in backing plates.
Axles have bearings pressed on and are ready to be picked up.
Rear pinon yoke is derusted and ready for paint
All four backing plates are painted and ready for assembly.
The flu has been going around, Ive had it all week, my machine shop has not done any work on the block due to workers being ill. I still dont know deck height so I can figure out CR and internals.
Georgia200
Post #8 by Georgia200 » Fri Feb 15, 2019 11:31 pm
Closer....
Ive got to figure out how to get the seals out of the 8in.
Georgia200
Post #9 by Georgia200 » Sun Feb 17, 2019 8:18 pm
Flu is kicking my butt this weekend.
Races out of hubs, hubs cleaned up. I think Im going to have the drums turned.
Front backing plates ready for assembly.
Rear end painted.
Rear end is ready for seals and reassembly.
Looks like next weekend for the 4 to 5 lug swap.
Only a month behind schedule.
Georgia200
Post #10 by Georgia200 » Fri Feb 22, 2019 9:11 pm
Finally ready to roll it under the car.
8in 2.79 gears 10x1.75 drum brakes
Georgia200
Post #11 by Georgia200 » Sun Feb 24, 2019 11:04 pm
8in is in.
Need to bleed the brakes and work on the hand brake cables. (My car didnt have one.)
driveshaft and u-joints bolted right up.
Having some issues with the new brake lines, so no brakes.
Fronts are ready to go on.
Tires are 215 75 14. I hope they are not to tall.
Wheels are 14x6 Torino GT.
I hope to be completely 5 lug and on the road by the weekend.
Matthew68
Post #12 by Matthew68 » Fri Mar 01, 2019 2:42 pm
Looks awesome! Nice work on all of this. Thanks for sharing!
Georgia200
Post #13 by Georgia200 » Sat Mar 02, 2019 9:42 pm
Nothing done this weekend.
I had to do some needed maint on my Fusion and Civic. Those are my two work cars. The Fusion gets about 1200 miles a week and the Civic about 600 miles a week. The Civic just hit 300k.
Georgia200
Post #14 by Georgia200 » Wed Mar 27, 2019 4:45 am
Its been a long month.
Im 5 lug all around. Bled, adjusted and working.
My car is missing the bracket on the passenger floor pan for the hand brake cable. Ive got a plan to use an eyebolt through an existing hole in the frame rail. Hope to have that installed and working this weekend.
I think my booster needs a rebuild.
bmbm40
Post #15 by bmbm40 » Wed Mar 27, 2019 8:37 pm
That is a lot of work you have done and it will pay off with all those upgrades. Definitely will enhance your driving experience.
Georgia200
Post #16 by Georgia200 » Sat May 04, 2019 5:41 pm
Nothing significant to report.
Ive been busy with work, yard work, house and grand kids so the cars have been on the back burner.
Georgia200
Post #17 by Georgia200 » Thu Jul 11, 2019 9:16 pm
Slow going. Discovered the heater core leaking.
Thought it would be a quick core replace. Noooooooooooooooo. Control cables shot, heater box has no seals, no defrost vents.
Pulled the heater box, firewall pad, driver vent, carpet, seats.
Bought necessary replacement parts.
Cleaned up pan, dyed carpet, replaced heater core, rebuilt heater box, replaced firewall pad.
The passenger cowl is in excellent condition, the driver side, not so good.
I cut out the hat, derusted what I can reach and am about to install a plastic repair hat. Its the best I can do from the inside and will hold for a few years since I keep the car inside.
Once the interior is back together I will move under the hood.
falconcritter
Post #18 by falconcritter » Sat Jul 13, 2019 8:48 am
I had too fix my heater core too on my 69 Falcon . My car was a weekend warrior for nine months before I got around to it . Keep up the good work !
1969 Ford Falcon 2Door and future home for my Australian 250 2V , 2013 Ford F-150 Single Cab , 2018 Ford Escape S
wsa111
FSP Moderator
Post #19 by wsa111 » Fri Jul 26, 2019 9:39 pm
Anybody have any comments on an aluminum heater core???
Georgia200
Post #20 by Georgia200 » Mon Sep 02, 2019 1:00 am
Picking up a fresh shortblock on a 250.
Pretty sweet deal, oem specs. I think I will change the cam and shave the head to bump compression, then its going in.
