<<< New Site Update >>>
Splicing off the light switch, which wire?
spacecadet
Post #1 by spacecadet » Mon Aug 05, 2019 8:50 am
I've tried searching, I can only find low res copies of the wiring diagram...
1968 Mustang Coupe
I'm installing a gauge and I want to tap into the light switch, does anyone know which wire, number or color? The loom looks original.
Thank you-
powerband
FSP Moderator
Re: Splicing off the light switch, which wire?
Post #2 by powerband » Tue Aug 06, 2019 8:45 am
For gauge illumination circuit, you could also tap/splice into the fuse panel /wiring if simpler to ID.
spacecadet
Post #3 by spacecadet » Tue Aug 06, 2019 11:49 am
I would like for it to work off the light switch. You are suggesting just wiring the light to switch on power?
powerband
FSP Moderator
Post #4 by powerband » Tue Aug 06, 2019 2:34 pm
You're right, you need to be after the Light Swx's Rheostat dimmer ...
