Electric Fuel Pump
Mr Comet
Electric Fuel Pump
Post #1 by Mr Comet » Fri Sep 06, 2019 6:24 pm
If any one converted from a mechanical to electric fuel pump please share some info namely the brand and model pump you used and where you mounted it. Thanks in advance.
DoctorC
Re: Electric Fuel Pump
Post #2 by DoctorC » Fri Sep 06, 2019 8:59 pm
Vintage inline sells them. I bought it with my Weber upgrade then chickened out.
Support those who support you!
-DrC
1967 Cherry Red Mustang
Weber 32/36,
MSD 6AL+MSD Coil,
Duraspark 2 dizzy
chad
which/who's Electric Fuel Pump
Post #3 by chad » Fri Sep 06, 2019 9:57 pm
mount lower than tank, near tank as they R 'pushers' as I have heard...
Matt at VI is all ways the 1st check...
powerband
FSP Moderator
Post #4 by powerband » Sat Sep 07, 2019 1:58 pm
... depending on your fuel supply needs, the type of electric pump application is important. Are you simply replacing the mechanical pump with an inline low pressure pump or adding an electric fuel pump system suitable for fuel injection, forced induction or other performance upgrades.
" Everything in my garage has a story ..."
Mr Comet
Post #5 by Mr Comet » Sat Sep 07, 2019 6:57 pm
Simply replacing the mechanical pump. I understand from Holley's page it 2-9 lbs pressure I need.
Cool23
Post #6 by Cool23 » Sat Sep 07, 2019 7:52 pm
I run one with the 170 Pursuit Engine in my T Roadster. I can not remember what brand now and you will find smaller more compact units available now. It needs to be at the fuel tank and set to push to the Engine. Run it with a cut off switch as both anti theft and in case you have problems.
V8's are great but Six Inlines Just Fine. Cummins Advert.
The link to my project on this forum http://fordsix.com/forum/viewtopic.php?t=41598
DoctorC
Post #7 by DoctorC » Sun Sep 08, 2019 9:48 am
If the only reason your going to do it is to control the pressure, I highly recommend you just install a pressure regulator.
The reason I chickened out was because I read to many complaints and woes of people that can't stand the nose it makes. Since it's mounted to the frame...
I'm super happy with my regulator. And was a cinch to install.
Weber 32/36,
MSD 6AL+MSD Coil,
Duraspark 2 dizzy
chad
Y use an Electric Fuel Pump if not needed?
Post #8 by chad » Sun Sep 08, 2019 10:12 am
"...and in case you have problems...."
"...I read to many complaints and woes of people..."
They R dangerous.
powerband
FSP Moderator
Post #9 by powerband » Sun Sep 08, 2019 11:45 am
They R dangerous.
... only if installed without regard to standard safety practices. For safety, electric pump systems should incorporate at least an oil pressure switched power source ( with ign,/start bypass) in case of a fault/leak in fuel supply. Factory setups typically also include a rollover valve for worst case scenarios ...
https://www.summitracing.com/search?Sor ... y%20switch
(250 oil pressure port tapped for FP safety oil pressure/Ign bypass switch, SC oil line feed, original lamp switch and NHRA compliant metallic cabin oil pressure gauge line.)
... personal worst case scenario involved a 'Mr G@$%^t dial type fuel regulator on a mechanical pump, which ruptured and PUMPED fuel on engine (Headers, ign etc ... ) until engine shut down ('63 Wagon Pursuit 170) ...
chad
Electric Fuel Pump v mechanical
Post #10 by chad » Sun Sep 08, 2019 2:14 pm
whasssat 'impact switch' too?
a la late 20th century, early 21st century cars
Users browsing this forum: wsa111 and 16 guests
