Which distributor vacuum advance
twodogs
Active member
Supporter 2021
Hi all. I have a '74 Bronco with a 200 ci inline six engine. My distributor vacuum advance is leaking quite a bit and I would like to find a new replacement. So far I've had zero luck in locating one. My distributor is marked, "Motorcraft D3BF-12127-CA." I can easily find one for a 302, but have struck out completely on one for my 200. Thank you for any help you can provide!
Brent
You would be better to upgrade to a DS11 or a HEI distributor. Bill
Hi, I see you got your answer on the classic bronco site. I find many of the parts I need at my local parts stores. I try napa and advance on line. They often have what I need in stock. It is good to see you are making progress with your Bronco. I would recommend two reference books: the Ford Falcon Performance Handbook from Vintage Inline, and a Chilton's Manual. Good luck
yes, many here use 'the Handbook' @ (2nd item):
https://www.vintageinlines.com/distributors
(we stay away frm the DUI dizzy, by-and-large).
The 200 was in the '73/4 bronk only so as B RON sez - the lill 'canister' is avail @
AutoZone, etc as a Y/M/M item...let us know how U do !
