All of the tubes are mild steel, mandrel bent, U-bends that I purchased from Don's Hot Rod (local speed shop). They're heavier guage (14gage) then standard exhaust pipe. Very easy to work with. Just measure, measure again, cut, tack in place, measure the next piece, repeat! I just used a Mig to weld it all. It would be better to use a Tig but I don't have one.....yet!
The regulator I'm using is a Mallory 4309. It uses a return line. It's also boost referenced. No cool can. The pump is a very large Mallory 250. The only reason I'm using this pump is because I already had it. This pump can easily drown the 250. I'm regulating it down to around 7psi initial, and also slowing the pump down with a inline variable resistor. I'm trying to figure out a resistor that's hooked to the accelerator. The more I push the pedal, the more voltage to the pump.
Ya I can't wait to see how it goes too! We'll drive it this weekend after I get the throttle cable fab'd up.
