2018 Contributors:
The new OLD FTF gets a "Duesenberg DOHC 4-valve"
shmoozo
Post #151 by shmoozo » Tue Feb 10, 2009 2:31 pm
THE FRENCHTOWN FLYER wrote:Another of my rules for car building: Never put a 9-second motor in a 12-second chassis. Fastest recipe for disaster I know.
Yeah, I can see where that would be true. It's the sort of truth that has a very nasty way of proving its point to anybody foolish enough to ignore it (or at least to those who happen to be watching when the inevitable disaster strikes).
On the other hand, putting a 15-second motor in a 9-second chassis might not be such a terrible idea from a safety perspective, but a proper 9-second chassis is probably not terribly well suited for the sort of application where one would be using a 15-second motor.
"Sorry about the door bars, grandma. Watch out that you don't bang your head on the roll cage tubes. Now, let me show you how to buckle yourself up in that aluminum racing seat using the 5-point racing harness and then we'll get you to the pharmacy to renew your osteoporosis prescription in a jiffy. Oh, by the way, the ride might be a little bumpier than you're used to, but ... "
"Every normal man must be tempted at times to spit upon his hands, hoist the black flag, and begin slitting throats."
-Henry Louis Mencken
Post #152 by THE FRENCHTOWN FLYER » Sun Apr 19, 2009 5:27 pm
I did a little more work on the nosepiece. The fender sections from a '46 truck were so hard I could not work them, so I built a roaring brush fire and threw them in for a few hours. That annealed the steel so I can start to stretch and shrink them. Here is how far I got in an hour:
shmoozo
Post #153 by shmoozo » Sun Apr 19, 2009 10:46 pm
THE FRENCHTOWN FLYER wrote:I did a little more work on the nosepiece. The fender sections from a '46 truck were so hard I could not work them, so I built a roaring brush fire and threw them in for a few hours. That annealed the steel so I can start to stretch and shrink them. ...
Will that annealing process leave the metal in the nose soft and easily damaged or will other processes along the way (work hardening, for example) strengthen it again before the nose is finally installed on the car?
Post #154 by THE FRENCHTOWN FLYER » Mon Apr 20, 2009 12:06 pm
It is much softer than before. It will work harden somewhat with further shaping. The compound curve shape makes it very strong, like an eggshell is strong even though its material is inherently brittle. Being steel rather than aluminum I am not worried about its strength.
Post #155 by THE FRENCHTOWN FLYER » Thu Apr 30, 2009 2:17 pm
Recently I found this neat magnesium center section at a local scrap yard. It was erroneously tossed into a bin of scrap aluminium castings and I was able to buy it for scrap (aluminum) value. What I would like to do is marry it to my 9" roundback rear end housing to give me the strength of a niner and the look of a quickie. Can anybody identify the manufacturer? I would like to find a used / used up rear end cover for it but I don't know whose to look for. The single most distinguishing feature to me is the absence of a twelvth hole on the axle flange near the change gear case. If I have to I'll hog a rear end cover out of a billet of aluminum but the thought of a billet piece on this car makes me shudder.
Any ideas? Halibrand? Winters? Other?
shortbox07
Post #156 by shortbox07 » Thu Apr 30, 2009 2:54 pm
i believe speedway sells a weld on piece that looks just like that. you trim it to fit for the 9" to get that look. if i had to take a guess id say its a winters probably from a sprint.
A guy at the local parts store once asked me if i own any vehicles that aren't made up of 10 other vehicles ... i replied whats the fun in that!
my "six" collection
78' f-100 shortbox 300
67' mustang coupe 200
Re: The new OLD FTF gets a "Duesenberg DOHC 4-valve"
Post #157 by THE FRENCHTOWN FLYER » Mon May 11, 2009 3:30 pm
Yup, its a Winters. Heres a pic trimmed to fit a 9".:
Post #158 by THE FRENCHTOWN FLYER » Mon May 11, 2009 3:37 pm
Post #159 by THE FRENCHTOWN FLYER » Tue May 19, 2009 11:59 pm
Here is the nosepiece:
Anlushac11
RC/TS Moderator
Post #160 by Anlushac11 » Tue Jul 07, 2009 3:59 pm
I cant wait to see that finished. I really love the look of the old classic open wheel racers.
3.3L n C4 installed, working on wiring for Duraspark II, trans lines, fuel lines, carb linkage.
Post #161 by THE FRENCHTOWN FLYER » Sun Jul 12, 2009 11:17 pm
The rear suspension is completed:
The chassis is finish welded:
Work continues on the body sections. The rear section is roughed in:
shmoozo
Post #162 by shmoozo » Mon Jul 13, 2009 5:44 pm
I like what I am seeing. I'm guessing that the lower edges of the rear body section will be contour cut to get it sitting down lower onto the frame once it's a bit more complete, but that for now it's easier to just build it with straight bottom edges to simply the fabrication process.
It looks like you have the front axle way out in front of the engine. That appears like it will give you a fairly even weight distribution front to rear, and also stretches out the wheelbase which could also improve the ride quality and also the straight-line stability at speed.
Nice.
Post #163 by THE FRENCHTOWN FLYER » Mon Jul 13, 2009 10:29 pm
The nosepiece will set further forward and cover the front axle. I am going to put the tie rod behind the axle as soon as I figure out the steering arm geometry. The tail will set down lower on the frame and a belly pan in the rear will all but cover up my "halibrand quick change". I need to establish the hood line. Once that is done I can place the steering box and hook up the steering. Then the cockpit and fuel system. Then test drive - whoohoo.
I am in need of six exhaust valves of the following dimensions:
5.180 OAL
.345 tip length to top of square groove
1.44 head diameter
11/32 stem dia
44 degree seats
.080 margin
If you know of a larger valve head diameter that can be cut down I can do this. Any suggestions?
66Sprint6
Post #164 by 66Sprint6 » Tue Aug 18, 2009 2:15 pm
Goodness...i lost track of this project and just remembered it. You have come a long way, and its startin to get interesting! Cant wait to see whats next!!!
Matt
"ITS A SIX!!!!!"
Post #165 by THE FRENCHTOWN FLYER » Thu Mar 25, 2010 11:23 am
I found this movie link on another site. It stars Jack Nicholson and has some cool short track racing scenes in it about half way through the movie. Great inspiration for my project. Go Jack Go. By the way, the movie plot is horrible. The movie is called "Wild Ride". Enjoy
http://www.liketelevision.com/liketelev ... heme=guide
Austin
Post #166 by Austin » Fri May 21, 2010 12:31 pm
this is the neatest 6 build i have ever seen its awsome
1969 f-100 300-6 hedman header, true dual 2.25 exhaust, modrate cam, .030 over duraspark dizzy recurved with 925d spring
A hot rod has a Ford up front with a tool box in the back,
A street rod has a Ch#$y up front with a can of wax in the back. ( Fred Offenhauser)
worken2much
Post #167 by worken2much » Mon Jul 19, 2010 11:02 am
Looking good! Just once you need to slap some big honkin Hoosiers on it and travel to Knoxville, Iowa for their annual vintage dirt event. Everything there from soup to nuts. Propane powered midgets, Red Ram hemi powered cageless wire wheel sprinters, 302 gmc six powered track t-roadsters. If those don't get your heart pumpin, you better go to see the doctor.
Your double overhead cam Ford / Duesy secret race six would fit right in. On track pace entirely up to driver. Stand on it, or motor around the bottom at 50 mph. Either case will leave you grinning like a fool for days. Knoxville sprint car museum located on back stretch is a must see as well. Cammer Ford sprinter on display plus many more.
Keep up the good work!
Worken2much
Rule #1. Six Cylinder Racers Have Longer Cranks.
Rule #2. Unless your given name is Richard...don't be a dick.
Post #168 by THE FRENCHTOWN FLYER » Mon Jul 19, 2010 10:01 pm
worken2much wrote: Stand on it, or motor around the bottom at 50 mph. Worken2much
For me motoring around the bottom would be standing on it as I have zero experience on dirt tracks.
Seriously, did somebody say 302 GMC track roadsters? Lemme at 'em!
I will put this event on my bucket list.
Post #169 by THE FRENCHTOWN FLYER » Wed Sep 22, 2010 11:37 pm
I had my chassis man bend up the main hoop for the roll bar. 1.5/8 DOM x .134 wall.
woodbutcher
Post #170 by woodbutcher » Thu Sep 23, 2010 11:21 pm
:beer: Hi FTF.Looking better all the time.
Leo
Otto von Bismarck
MPGmustang
FSP Moderator
Post #171 by MPGmustang » Fri Oct 08, 2010 6:12 pm
I'm tempted to drive out where your gonna race it just to see this thing in person...
:thumbup:
65mustang-SOLD-200ci-t5-scarebird disks-vintage air ac-264/274 110 cam-mav 8inch 3.8 open-350cfm-CI headers
66 Bronco-SOLD-i6 170 - rust bucket never ran...
75 bronco-SOLD-v8 c4 dana 20 33's and disk brakes, locker front/rear.
Post #172 by THE FRENCHTOWN FLYER » Fri Oct 22, 2010 7:45 pm
Today I made the steering mounts. This crossmember will be mounted inside the frame rail and the dash wiring will be hidden inside it.
FoMoCowboy
Post #173 by FoMoCowboy » Fri May 20, 2011 1:01 pm
That is some awesome fabrication, I mostly ran through and looked at the pictures, but I'm assuming you did it all yourself. Amazing. should be alot of fun when its done!
Hoof beats are faster than heartbeats!
1993 F150 Flareside, 300, Mazda Trans and 2.73:1 rear
1990 F-350 4-door, Passes everything but the gas station with the 460 under the hood
1986 2WD Ranger
MustangSix
Assistant Admin
Post #174 by MustangSix » Mon Oct 31, 2011 3:14 pm
So, what progress have you made in the past year?
I really want to see this car running!
Jack Collins
woodbutcher
Post #175 by woodbutcher » Mon Oct 31, 2011 5:23 pm
:beer: Better yet.Hear it run.And some action video.
Good luck.Have fun.Be safe.
Leo
Otto von Bismarck
Post #176 by THE FRENCHTOWN FLYER » Mon Oct 31, 2011 11:42 pm
I put this car on the back burner, so to speak, to finish up the '46 truck I plan to use as its tow vehicle, and also to finish up "the Last Logghe altered " roadster which I also got running recently. Now that those two projects are running and nearly complete I will resume my efforts on this project in the Spring. I recently installed a set of straight-cut timing gears which should give this engine a nice whirr - like an old centrifugal supercharger might sound - but I got the timing on the cam off so it has to come back apart to reset the cam timing. I also visited with noted sprint / champ / midget car restorer Josh Shaw of Cincinnati last week to pick his brain and get inspired by some of the restoration projects he is working on.
www.shawhotrods.com
I usually have several projects going on at once so hang with me as no one car progresses at record pace.
Post #177 by THE FRENCHTOWN FLYER » Wed Nov 02, 2011 11:38 am
Josh let me squeeze into one of their customers restoration cars. By the way if you want a replica of this car they can entirely reproduce one for a little under...
...ONE MEEELION dollars.
Post #178 by bubba22349 » Wed Nov 02, 2011 4:12 pm
:hmmm: It looks like a tight fit, bet that would be a fun ride :nod:
:rolflmao:
Post #179 by THE FRENCHTOWN FLYER » Wed Nov 02, 2011 7:32 pm
bubba22349 wrote::hmmm: It looks like a tight fit...
I'll say. The steering wheel is cut away so only 270 degrees of it remains. That is so you can clock the opening to get one leg in the footwall then move the wheel opening to allow the other leg to enter the footwell. But as Mr. Shaw says, recalling his very successful career as a driver of more modern sprint cars once you are in "I fit perfectly." That's my story.
Post #180 by bubba22349 » Wed Nov 02, 2011 8:19 pm
:thumbup: so you wear it. I never had the chance to see one up close
Post #181 by THE FRENCHTOWN FLYER » Thu Nov 03, 2011 12:23 pm
Pretty much. Also no doubt the drivers of the day were at least a foot shorter than me. On my car I am using a C4 trans behind the engine instead of direct drive. That will give me an additional foot of leg room vs an original. The body is going to be a skosch taller too.
Post #182 by THE FRENCHTOWN FLYER » Fri May 11, 2012 9:38 am
I found a nice crab-style distributor cap last weekend. I plan to mount it on a dummy distributor off the end of one of the cam towers. It is a six cylinder cap of unknown make. Anybody have a clue as to what it originally fit? I made a simple base for it and will run a cloth covered wire to it and maybe an external brass capacitor a la Mallory.
Originally I was going to use a flattie cap, but this one works better. I may have to blister the hood to fit it in there. Or just mount it on the rear of one of the cam towers. We'll see.
clintonvillian
Post #183 by clintonvillian » Thu May 31, 2012 9:29 pm
What thickness of steel did you use for the headers, and flanges?
I saw a .25" on the aluminum intake is that correct? Any reason the intake couldn't be made out of some thinner/lighter stainless???
Post #184 by THE FRENCHTOWN FLYER » Thu May 31, 2012 11:17 pm
Exhaust: .060 on the primaries; .070 on the pipe
Intake: .375 flange; .125 on the runners.
Lazy JW
FSP Moderator
Post #185 by Lazy JW » Sat Jun 02, 2012 9:17 am
THE FRENCHTOWN FLYER wrote:--------------------------------------------------------------------------------
Seems like I recall seeing this type of cap on an old farm tractor. Oliver, maybe?
Joe
"The White OX" 1974 F-350 300-6, Stock single exhaust, Carter YF, T-18A, Dana70 w/4.11, Flatbed dually w/dump bed. "Where no oxen are, the crib is clean, but much increase is by the strength of the ox" (Proverbs 14:4)
Post #186 by THE FRENCHTOWN FLYER » Sat Jul 28, 2012 2:41 pm
I fitted up the spindles, made a new tie rod and mounted the "distributor" off the cam cover:
Now I can mount the steering box, make a drag link, a front panard bar, and lever shocks.
__________________
Post #187 by THE FRENCHTOWN FLYER » Sat Oct 13, 2012 6:35 pm
Here is the steering box mounted on the frame:
Now I need a drag link and steering wheel adapter then I can make the rest of the front of the body work.
Post #188 by THE FRENCHTOWN FLYER » Thu Oct 18, 2012 6:30 pm
Another silly little detail job - a stone/mud guard to go in front of the front axle. Most stone guards were crude "chicken wire" affaies. I made this one and ran it through the beader to offset flange the edge, then powdercoated it black and put a brushed aluminum framework around it. I'll stencil the car number on it later.
Post #189 by bubba22349 » Thu Oct 18, 2012 6:49 pm
:thumbup: FTF, you sure do nice work :nod:
Post #190 by THE FRENCHTOWN FLYER » Thu Oct 18, 2012 7:41 pm
bubba22349 wrote::thumbup: FTF, you sure do nice work :nod:
Thank you.
Post #191 by THE FRENCHTOWN FLYER » Sat Nov 10, 2012 11:16 pm
I did some more work on the driver compartment buck. This buck is a little unique in that I am making it to fit onto the chassis with the steering components in place so I can shape the body in situ.
http://smg.beta.photobucket.com/user/6r ... sort=3&o=2
I blanked out the side panels.
http://smg.beta.photobucket.com/user/6r ... sort=3&o=1
Next, roughed out the firewall with room to fit over the trans hump.
Then started to fit up the sides.
http://smg.beta.photobucket.com/user/6r ... sort=3&o=0
otto69
Post #192 by otto69 » Sun Nov 11, 2012 7:03 am
Excellent project you've got going there :thumbup:
Great work
Post #193 by THE FRENCHTOWN FLYER » Fri Nov 16, 2012 9:54 pm
The cowl is roughed in. It will be trimmed, rolled and wired on the top edge. A cutout will be added for the strreing arm, and a gage panel added below the steering wheel.
1986F150six
Post #194 by 1986F150six » Mon Nov 19, 2012 10:09 am
You are so very talented and diligent. Thanks for sharing!
Post #195 by THE FRENCHTOWN FLYER » Mon Dec 10, 2012 4:45 pm
After some hammering and some welding and some more hammering the cowl looks like this:
http://img.photobucket.com/albums/v608/ ... cowl07.jpg
Now it needs to be fitted to the chassis, edge wired, skim coated and detailed.
Post #196 by bubba22349 » Mon Dec 10, 2012 6:31 pm
Very nice metal work :thumbup:
Post #197 by THE FRENCHTOWN FLYER » Wed Dec 19, 2012 12:26 am
Body panels in place. Steering needs to be hooked up next.
clintonvillian
Post #198 by clintonvillian » Wed Dec 19, 2012 8:26 am
Looking real good. Curious to see how it sounds!
Post #199 by THE FRENCHTOWN FLYER » Wed Dec 19, 2012 9:03 am
Thanks. I'll get some audible vids and hopefully some in-car shots out on the track - and maybe in traffic. But that's a long way off. I can be VERY patient.
clintonvillian
Post #200 by clintonvillian » Thu Dec 20, 2012 2:31 pm
French,
Have you or anyone you know ran an intake made similar to yours? I am wondering if there are any ill affects of having the square corners inside the intake instead of a nice fillet in them???
