Knock sensor
Bayrunner
Knock sensor
Post #1 by Bayrunner » Sat Oct 24, 2009 12:00 am
Fellas,
Where is the best place to install a knock sensor in a 200ci?
Former Cars
69 Mustang Mach 1. Yellow
04 Mustang Mach 1. Screaming Yellow
03 Maserati Spyder Grand Sport F1
Current Cars
66 Mustang Coupe. 250 X Flow Conversion. 570 HP at Crank. Looking to break 700 with a larger Turbo.
08 H3 X -
3each Range Rovers for daily driving.
fordconvert
Re: Knock sensor
Post #2 by fordconvert » Sat Oct 24, 2009 9:42 am
Dont know. Till recently I thought it was a very complicated thing to figure out and get to work properly (like only in a lab). I now read that there are multiple vendors that sell a universal one. Not sure if I believe it or not. Its logical to me that you would have to do some experimenting and tuning to get it in an optimum location so it picks up as soon as possible but does not false trigger from other normal noises. From what I gather the aftermarket ones are just to keep you from instantly blowing up a boosted engine. I somehow doubt they are good enough to work like the factory designed and located ones where they can keep it adjusted to ride just on the edge of detonation all the time.
TJ H
Had a 66 mustang coupe, traded in for a 93 convert 2.3.
73 Eldorado convert 8.2 megasquirt, 80 Eldorado 5.7 diesel, 96 Suburban 6.5TD, 05 Magnum 5.7 hemi.
MustangSix
Assistant Admin
Re: Knock sensor
Post #3 by MustangSix » Wed Oct 28, 2009 7:38 am
The Aussie crossflow engines mounted a sensor on one of the forward cylinder head bolts. A similar arrangement might work well, but since you don't have any finite data you'll need a tunable system to be able to adjust the response. And l think most sensors require some additional electronics to convert the signal from the sensor into something that the ECU can use.
Jack Collins
FLSHBCK
Re: Knock sensor
Post #4 by FLSHBCK » Wed Oct 28, 2009 2:16 pm
FWIW, GM 3800 Series II have 2, one on each side in the middle of the block, just below the exhaust manifolds - they screw into the water jacket...
'65 Mustang Hardtop 200, C4: Rust repair in progress
'12 Malibu LT3 - Wow; there are NO aftermarket parts for this thing
'04 Jeep Wrangler X - 4.0L I-6; stock
fordconvert
Re: Knock sensor
Post #5 by fordconvert » Wed Oct 28, 2009 3:36 pm
I read the instructions for one of the aftermarket sets and I believe it also recommended a cooling port. I wonder if that is because the cylinder walls are much thinner than the heads? You would think the liquid would dampen things but maybe at those frequencies it helps by damping out other sounds?
TJ H
Anlushac11
RC/TS Moderator
Re: Knock sensor
Post #6 by Anlushac11 » Sat Oct 31, 2009 12:55 pm
I was thinking it might be because sound travels faster through a solid than through air, thus the signal a knock sensor was listening for would be stronger and arrive a fraction of a second sooner.
Plus if the sensor was in the water jacket seems like the sensor would be closer to the noise source.
3.3L n C4 installed, working on wiring for Duraspark II, trans lines, fuel lines, carb linkage.
Greg
Re: Knock sensor
Post #7 by Greg » Sun Nov 01, 2009 10:42 am
I mounted mine on one of the bolt holes previously used to mount the brackets for the power steering pump braces. It is on the drivers side of the engine towards the front. The sensor and signal converter I purchase let's you adjust the gain of the signal and appears to work well. I have to get the throttle body finished so I stop leaning out the engine to be sure. Whenever I get time to work on it again I'll take some pictures.
Greg
Bayrunner
Re: Knock sensor
Post #8 by Bayrunner » Sun Mar 07, 2010 3:42 pm
Greg wrote:I mounted mine on one of the bolt holes previously used to mount the brackets for the power steering pump braces. It is on the drivers side of the engine towards the front. The sensor and signal converter I purchase let's you adjust the gain of the signal and appears to work well. I have to get the throttle body finished so I stop leaning out the engine to be sure. Whenever I get time to work on it again I'll take some pictures.
Greg
Any progress?
Can you list the part used?
Former Cars
Current Cars
08 H3 X -
Turbo_B
Re: Knock sensor
Post #9 by Turbo_B » Thu Apr 01, 2010 8:58 am
Here is the knock setup that I have.
http://www.viatrack.ca/
In the MGB with its solid lifters, there was too much noise for the sensor to work. I have pulled this thing out of the MGB and will be putting it on the 300 after the machine shop returns my block. My hope is that the hydraulic lifter 300 will be quiet enough for the sensor to work.
1969 MGB - Bored, cam'd, aluminum head, MSEFI, turbo charged and intercooled at 10.5psi
1989 F150 - Stockish rebuild, Comp Cam, Megasquirt, turbo charged and intercooled at 14psi
fordconvert
Re: Knock sensor
Post #10 by fordconvert » Thu Apr 01, 2010 10:19 pm
Interesting. Is there a section that talks about mounting locations?
TJ H
Greg
Re: Knock sensor
Post #11 by Greg » Fri Apr 02, 2010 6:37 am
There is a sensitivity adjustment on the knock sensor I used (http://www.viatrack.ca/) and it seems to work. Althou, when I get up in the RPMs it knocks all the time. I'm not sure if it is the engine leaning out or the noise in the engine. I do not have megasquirt controlling fuel and no o2 sensor. You can configure megasquirt to ignore the knock sensor over a specific RPM. It is ough to determine what is knock and what is noise in the engine. I think my issue at high RPMs is noise in the engine as I have dialed back the timing and still get the knock indication.
Greg
Re: Knock sensor
Post #12 by xctasy » Wed Sep 04, 2013 1:57 am
When I did mine, I used the coomon 60 pin plug EEC 4 Ford Falcon XF 1986 to 1991 E6RF-12A69BA item, which looks similar to the old EEC3 and EEC4 Panther platform items for 302 and 351 from 1981 to 1991. It mounts on the common earth strap for the log head bolt number one, US drivers side front bolt. The Alloy head bolt, also used on Classic Inlines engines, is about 0.875" taller, but uses the same sensor bolt as my 1972 XA Falcon engine.
The sensor is Fig 13 on the Page 221 Tomco website listing http://www.tomco-inc.com/Catalog/knock%20sensors.pdf, looks the same as the F150 4.9 six as well. Tomco 22 or 42 (29022 and 29042)
Tomco listes them differently to Standard Parts #KSxx listings, but the Ford knock sensor was the first to the US market in 1981 as a type 21 item, Tomco part number 290021.
The Aussie ford item just polls an on off 3 volt signal back to the EEC4, and that cuts the TFI timing back.
rbohm
Assistant Admin
Re: Knock sensor
Post #13 by rbohm » Fri Sep 06, 2013 1:17 am
fordconvert wrote:I read the instructions for one of the aftermarket sets and I believe it also recommended a cooling port. I wonder if that is because the cylinder walls are much thinner than the heads? You would think the liquid would dampen things but maybe at those frequencies it helps by damping out other sounds?
actually sound travels faster in water than in air. back in world war two, submarines would fire torpedos when running on the surface, those on the conning tower would watch the runs, and see the explosions, and at the same time the explosions would occur, the sonar operator would sound off "HIT", long before the sound of the hit reached the sub.
64 falcon
66 mustang
05 grand marquis
transient nodes of thought
of invention
redxm
Re: Knock sensor
Post #14 by redxm » Fri Sep 06, 2013 5:02 am
64 XM 4 door Deluxe
221 2V, 63666 Crow cam, ARP studs and bolts, EFI, Romac balancer, and lots of shiny bits.
woodbutcher
Re: Knock sensor
Post #15 by woodbutcher » Fri Sep 27, 2013 9:23 pm
:beer: Hi rbohm.Was wondering when someone was going to mention that.
Good luck.Have fun.Be safe.
Leo
Otto von Bismarck
