Super Red Diamond RD450 gasser
Firepower354
Post #1 by Firepower354 » Sun Feb 15, 2015 4:55 pm
I've been wanting an even bigger six, when I found this local.
Bottom end and valve gear is great. Sleeves (replaceable) and likely slugs are shot. A couple valve stems are sticky.
If the pistons can't be cleaned-up and coated back to stock size by Swain Tech, I could leave the sleeves out and run 4.5-4.6" pistons instead of the 4.375 stockers.
https://fbcdn-sphotos-g-a.akamaihd.net/ ... a32899522a
https://scontent-ord.xx.fbcdn.net/hphot ... e=55490B57
https://scontent-ord.xx.fbcdn.net/hphot ... e=559005D5
https://fbcdn-sphotos-b-a.akamaihd.net/ ... 18017ec24b
https://scontent-ord.xx.fbcdn.net/hphot ... e=555D2ED9
It gets 10MPG, but goes up to 14 if I lie.
Lazy JW
FSP Moderator
Re: Super Red Diamond RD450 gasser
Post #3 by Lazy JW » Sat May 02, 2015 8:45 am
I like it! :D 8) :thumbup:
"The White OX" 1974 F-350 300-6, Stock single exhaust, Carter YF, T-18A, Dana70 w/4.11, Flatbed dually w/dump bed. "Where no oxen are, the crib is clean, but much increase is by the strength of the ox" (Proverbs 14:4)
flatford6
Post #4 by flatford6 » Sun May 24, 2015 1:03 am
An even bigger International six in the same engine family: The RD 501. 4.5" bore without sleeves and 5.25" stroke with four barrel carb. I had one in an old IH ten wheeler and it had a significant power increase over the RD 450 it replaced. Rated horsepower at 3000; 215 from 1966 to 1972. Engine weight very heavy, estimated 1000 lb.
Firepower354
Post #5 by Firepower354 » Sun May 24, 2015 9:56 pm
flatford6 wrote:An even bigger International six in the same engine family: The RD 501. 4.5" bore without sleeves and 5.25" stroke with four barrel carb. I had one in an old IH ten wheeler and it had a significant power increase over the RD 450 it replaced. Rated horsepower at 3000; 215 from 1966 to 1972. Engine weight very heavy, estimated 1000 lb.
Yep. Old-timers seem to mention the rarity and fragile nature of the 501, plus the more difficult rebuild, unique timing set.
A couple ideas I'm mulling:
4.600 BBC pistons on custom rods, and offset grind the crank to BBC journal size and 5.5" stroke, I'll have a much lighter rotating assembly and 548 cubic inches.
501 pistons in the de-linered block, 477 cubes. Rare slugs. 534 pistons may be a decent option, still spendy.
Re-sleeve and use my old slugs, after blast and coatings, turbo with a Cat unit I have.
The manifold pad seems to be able to be machined for a 4v, but there are some nice flats on the runners to add a couple more 2v carbs and keep the looks, or build a simple tubing one, or pick up a 2x1 Ellis from eBay. They pop up often but seem to be mostly for the smaller port head. Mine has the 2.25 intake valves and 2" ports.
https://scontent-iad3-1.xx.fbcdn.net/hp ... e=5601DFD0
https://scontent-iad3-1.xx.fbcdn.net/hp ... e=55FB2638
Mine is like this. I thought of ditching stock intake, looping the exhaust outlets together, running turbo on the former heat-riser pad, building a logifold
https://scontent-iad3-1.xx.fbcdn.net/hp ... e=560433A1
Firepower354
Post #6 by Firepower354 » Tue Dec 27, 2016 11:00 pm
Sitting next to a 292, ready to get sonic tested, as soon as I get help loading the big gals.
sdiesel
Post #7 by sdiesel » Mon Dec 31, 2018 12:26 am
does any one know how this turned out?
Firepower354
Post #8 by Firepower354 » Thu Feb 21, 2019 11:05 am
Image Image Image Image Image Image Image Image Image Image
