"ODD" 1965 mustang 200ci. Dies when shaken.
+Wombratwombrat1
Post #1 by +Wombratwombrat1 » Fri Sep 16, 2016 7:08 pm
I dont think this is normal.. 1965 mustang conv. Starts, idles, acellerates good. Temps run good.
The odd thing i noticed is that when at operating temp, and probably worse on hotter days and alot of city driving, if i pop the hood and shake the car by grabbing the support bars and rock/shake the car left to right, it will stumble and die.. if the idle is set around 850-900 it stumbles and shutters but will manage to hang on. But if at 550-700 it will not be able to hold on and dies. Bouncibg from the fenders up and down it does fine.
For a test, from my air conditioned garage, as soon as i started it and it would idle on its own, and idling at 700rpm, i shook her and it had no affect. I let it idle for 10 minutes to full temp, same idle, and it died after a few shakes. Ive also noticed when full operating temp and slow traveling and stomping the brakes to a fast stop, it will die as well, I havnt done this cold yet, like i said, im satisfied with how it runs, but this is odd.. or is it?
Any thoughts?
+Wombratwombrat1
Re: "ODD" 1965 mustang 200ci. Dies when shaken.
Post #2 by +Wombratwombrat1 » Sun Sep 18, 2016 7:52 pm
Although no thoughts were given, i thought it may be helpful for someone to know in the future, i swapped the carb out with another,and all is good. Thanks
Post #3 by bubba22349 » Mon Sep 19, 2016 12:27 pm
+Wombratwombrat1 wrote:I dont think this is normal.. 1965 mustang conv. Starts, idles, acellerates good. Temps run good.
Any thoughts?
From your discription it sounds as though the carb's wet fuel level may be a bit too high. So it needs to be opened up to freshen it up with a carb kit and everything set to spec. it could also need a new float. Good luck :nod:
cr_bobcat
Post #4 by cr_bobcat » Tue Sep 20, 2016 12:38 pm
My guess would be that the float setting is off...
+Wombratwombrat1
Post #5 by +Wombratwombrat1 » Tue Sep 20, 2016 6:28 pm
Thanks, not sure what it was, but for sure in the carb. Soon as i switched it out with a known good one... all is good. Running great. Thanks
Users browsing this forum: No registered users and 7 guests
