2018 Contributors:
Time For a Radiator
sixty5mustang
Time For a Radiator
Post #1 by sixty5mustang » Sun Mar 26, 2017 12:52 pm
What radiator should I go with? My brass one is leaking at the tank. I soldered it twice and am tired of messing with it.
I have a mild 200 build with Weber 2 barrel conversion, 30 over, cam with 1:6 roller rockers. It was running a little warm last summer but nothing too crazy. Should I get a replacement from the parts store or one of the aluminums off ebay?
thanks
B RON CO
Re: Time For a Radiator
Post #2 by B RON CO » Sun Mar 26, 2017 3:03 pm
Hi, also check out the Mustang specialty parts guys. Good luck
1966 Ford Mustang - 289 V8
Llink78
Post #3 by Llink78 » Thu Apr 20, 2017 7:36 pm
I'm researching the same thing right now. Champion seems to make a nice aluminum in a couple varieties for six cylinder mustang's
sefus
Post #4 by sefus » Tue Jun 20, 2017 1:48 pm
anyone have the part number for the Champion that is confirmed to be a direct replacement for 200 6cyls in mustangs?
68 Mustang Coupe family car from the dealership til now. 96k original miles.
200-C4, Duraspark, MSD, Holley, Spectre, Bilstien, Zip Ties, Bud Light.
Angelking
Post #5 by Angelking » Mon Jun 26, 2017 8:18 am
Look at Speedway Motors.....
SM
sefus
Post #6 by sefus » Wed Jun 28, 2017 11:17 am
Maybe I missed it but speedway doesnt carry Champion and the only non $500 radiators they have are generics without brackets or tranny coolers.
sixty5mustang
Post #7 by sixty5mustang » Mon Jul 03, 2017 8:57 pm
I went with a BBK aluminum radiator off of Ebay. It works great. On a 70 degree day the engine will barely hit 120 degrees. on a 80 degree day it hits 150 degrees in traffic. Havent had it out on a 90 degree day to check it out on yet. Very happy with it so far.
Matthew68
Post #8 by Matthew68 » Wed Aug 16, 2017 8:56 pm
I am literally in the same boat as you. I called up Champion (68 Mustang here as well) and he said their 6cyl fitting radiator is the CC329. There may be others they sell that would technically fit, but this one has the exact OEM mounting specs. They also noted shipping to lower 48 is flat $29.
Here's a link to the radiator from their site:
http://www.championradiators.com/page/487081596
Hope that helps!
Cheers,
M
1968 Mustang Coupe 200ci - Pertronix + Coil
Gulfstream Aqua - Interior + Exterior
sixty5mustang
Post #9 by sixty5mustang » Thu Aug 31, 2017 9:23 pm
[quote="Matthew68"]I am literally in the same boat as you. I called up Champion (68 Mustang here as well) and he said their 6cyl fitting radiator is the CC329. There may be others they sell that would technically fit, but this one has the exact OEM mounting specs. They also noted shipping to lower 48 is flat $29.
Hope that helps!
Cheers,
M[/quote
not a bad price but the BBK radiator I bought for less money. Also it has a stamped aluminum top tank that looks a lot better in my opinion.
