Creaking after rebuild of front end
StarDiero75
Post #1 by StarDiero75 » Sun Oct 22, 2017 10:33 pm
Howdy everyone
So 3 months ago I rebuilt the front end, new perches, ball joints, bushings galore but I get a creak after the car has been running and I let it sit. It used to squeak real bad but that was due to the old perches, so I got new ones. If the car is cold I can lean in it while I work in the engine bay but if I've had it running and it's somewhat warm then it freaks when I mean on the front when I work on it. When it starts creaking I'll push hard on it like I'm testing how still the front end is then it goes away for about 1 minute or so but then it returns. Any ideas what's doing this?
StarDiero75
Re: Creaking after rebuild of front end
Post #2 by StarDiero75 » Sun Oct 22, 2017 11:11 pm
It's probably help that this is a 65 Ranchero L6
mustang6
Post #3 by mustang6 » Mon Oct 23, 2017 2:32 am
Usually upper A-arm bushings are the culprit. If yours have zerks you can grease them directly. If they have plugs you have to replace them with zerks to grease them.
Scott
ags290
Post #4 by ags290 » Mon Oct 23, 2017 11:35 am
X2 on the upper a frames causing the noise. Make sure that the end caps are not too tight. Make damn sure that they are not too loose.
Kevin
Kevin
Early 1965 Mustang with a 170
StarDiero75
Post #5 by StarDiero75 » Mon Oct 23, 2017 11:10 pm
ags290 wrote:X2 on the upper a frames causing the noise. Make sure that the end caps are not too tight. Make damn sure that they are not too loose.
Kevin
What do you mean by x2?
StarDiero75
Post #6 by StarDiero75 » Mon Oct 23, 2017 11:11 pm
mustang6 wrote:Usually upper A-arm bushings are the culprit. If yours have zerks you can grease them directly. If they have plugs you have to replace them with zerks to grease them.
I guess I can grease them again but I did them when I did the front. Any other thing?
