Diameter of Front Sway Bar 67 Mustang 6
wsa111
FSP Moderator
Post #1 by wsa111 » Mon Nov 13, 2017 7:03 pm
Need the original diameter of the front sway bar on a 67 Mustang CP 6 cyl no a/c & no Power steering. Thanks Bill
67 mustang,C-4, with mod. 80 hd, custom 500 cfm carb with annular boosters, hooker headers, dual exh.-X pipe, flowmaster mufflers, duraspark II dist. with MSD-6AL. Engine 205" .030" over with offset ground crank & 1.65 roller rockers. 9.5 comp., Isky 262 cam.
mustang6
Re: Diameter of Front Sway Bar 67 Mustang 6
Post #2 by mustang6 » Mon Nov 13, 2017 7:07 pm
I think it was 5/8" for the 200/289, 3/4" for the 390, and 13/16" for the "heavy duty" suspension option.
Scott
68 Mustang 200 ci, 250-2V head, H/W 5200, Dual Headers, Comp Cams 252H, DSII w/ MSD 6AL, T-5, V8 suspension.
wsa111
FSP Moderator
Post #3 by wsa111 » Mon Nov 13, 2017 10:14 pm
Thanks, i have a 7/8" front bar installed & i am getting a little oversteer. I am trying to find my original sway bar & give it a try.
I could probably fix it with a rear sway bar, but i don't feel like that unless thats my only option. Bill
Post #4 by bubba22349 » Tue Nov 14, 2017 6:12 pm
Many base model six's didn't have a sway bar, when they did X2 stock they were a 5/8 inch one. A 3/4 inch front and a 1/2 to 5/8 inch rear would probally also work very well togeather. Good luck :nod:
powerband
FSP Moderator
Post #5 by powerband » Tue Nov 14, 2017 9:20 pm
wsa111 wrote:... i have a 7/8" front bar installed & i am getting a little oversteer. I am trying to find my original sway bar & give it a try.
If I'm reading the post correctly, the 7/8 " sway bar is to be replaced with a smaller diameter 5/8". The reduction of the size of the front sway bar will INCREASE the cars' oversteer. Moving to larger sway bars should INCREASE understeer .
Front:
(1) Stiffer: Will increase overall car stability (reduces roll) and shift the car’s balance toward UNDERsteer (push), thus allowing the driver to be more aggressive with the steering. The compromise can be on bumps and/or braking. A stiffer front bar will reduce compliance, so when one tire hits a bump the entire front axle will be affected through a loss of overall grip.
(2) Softer: Allows more roll and will shift the cars balance toward OVERsteer (or less UNDERsteer.) And the front will improve in compliance, which improves performance in brake zones and over bumps.
http://iracing.wikidot.com/components:a ... r-sway-bar
Hav efun
I added a 5/8 " rear sway bar to my '63 Wagon that has a 3/4" front which reduced understeer significantly. The added rear bar does seem to increase steering input reaction related to higher speeds..
wsa111
FSP Moderator
Post #6 by wsa111 » Tue Nov 14, 2017 10:23 pm
Thanks, great link. I may try a 3/4" front bar cause i have new stiffer springs in front & 5 leaf in the rear. I also installed a set of Koni adjustable shocks. I will have to try different adjustments till i get it right.
I may up ending putting back the 7/8" front bar.
wsa111
FSP Moderator
Post #7 by wsa111 » Mon Nov 20, 2017 9:05 pm
Installed the 3/4" front sway bar. Very satisfied with the Koni shocks & the previous heavier front springs it handles very close to neutral.
I replaced all the junk Energy Suspension bushings with quality Moog parts.
The energy suspension bushings were showings cracks & degeneration after being in there for 5 years.
wsa111
FSP Moderator
Post #8 by wsa111 » Sun Nov 26, 2017 9:31 pm
After driving with the 3/4" bar i really like it. I will put my 7/8" bar for sale soon.
