pmuller9 wrote:
Recommend this turbo cam.
https://www.dropbox.com/s/qufkzkwyxoz8o ... m.jpg?dl=0
It is very important that the cam is installed with the intake lobe center at 110* ATDC.
Want to keep the compression low because of the early closing intake valve of the turbo cam.
The KB S3117H heavy duty piston with a 30cc stepped dish will work
Did I miss anything?
Pmuller,
I have a question/concern about the Crower cam quoted here. It doesn't specifically pertain to only this one, as I have seen it in almost every cam card I look at that they offer. What is going on with their .050" duration numbers vs their opening and closing points? None of them seem to match because of their addition errors or opening and closing points being incorrect. Have you had a chance to measure one and see which of the measurements on the cards are incorrect?
