How to remove steering shaft from box
StarDiero75
Post #1 by StarDiero75 » Mon Dec 18, 2017 6:16 pm
Howdy Guys
I have a 65 Ranchero 200 with manual steering. I just got done pulling it all out and im getting ready to send it in to get rebuilt. Does the shaft come off? Its like 3+ ft and i have to mail this in. Does anyone know how to remove the shaft?
Thanks,
Ryan
StarDiero75
Re: How to remove steering shaft from box
Post #2 by StarDiero75 » Mon Dec 18, 2017 6:52 pm
The ID tag says HCC AM1
Also, what diamter should this be? I used a 1 1/8" socket on the idler arm to get it off.
I have a choice between 1" or 1 1/8" so im trying to make sure which one i have
mustang6
Post #3 by mustang6 » Tue Dec 19, 2017 3:17 am
The shaft does not come off, that's why it is referred to as the "spear of death" in a front end collision. In late '67 Ford changed to a short input shaft box, the steering column got it's own collapsible shaft that bolted up to it, all for obvious safety reasons. Measure the non-threaded part of the output shaft (where the pitman arm was attached) to see if it is 1" or 1 1/8" diameter (in 65 I'm pretty sure it's 1" only).
Scott
StarDiero75
Post #4 by StarDiero75 » Tue Dec 19, 2017 12:54 pm
mustang6 wrote:The shaft does not come off, that's why it is referred to as the "spear of death" in a front end collision. In late '67 Ford changed to a short input shaft box, the steering column got it's own collapsible shaft that bolted up to it, all for obvious safety reasons. Measure the non-threaded part of the output shaft (where the pitman arm was attached) to see if it is 1" or 1 1/8" diameter (in 65 I'm pretty sure it's 1" only).
Man that sounds like it might just tickle. Haha. Is there an easy conversion to the 67 setup (like bolt on) or does it require cutting and stuff?
Thanks a bunch,
Ryan
mustang6
Post #5 by mustang6 » Thu Dec 21, 2017 2:59 am
I have seen something like that somewhere... just can't find it now. Of course if you wanted to change to power there is this integral power steering box conversion, I've installed it on a Mustang and it worked awesome:
https://www.borgeson.com/xcart/home.php?cat=121
Scott
mustang6
Post #6 by mustang6 » Thu Jan 04, 2018 5:35 pm
I also just put a short shaft (no spear of death) 67-8 Falcon steering box in the misc for sale section for $35. If you can measure the distance between the frame mounting holes on your box we could maybe determine if that box would bolt right in for you.
Scott
gtvongt
Post #7 by gtvongt » Wed Apr 25, 2018 3:12 am
I found this online, it may help.
