Heep of a jeep
64-5mustang
Heep of a jeep
Post #1 by 64-5mustang » Thu Dec 28, 2017 9:42 pm
Unfortunately my pony is now taking a back seat as I just blew the trans in my jeep. It's a 71 jeep commando with a buick 225 odd fire and t 14 trans dana 20 t case. you first gen bronco guyshave a real similar set up. I want a different trans period. I suspect a cracked head as I did head gaskets in high school really slowed down a coolant leaks popping up all over buts now it's just as bad again. I'm looking to swap the whole power train. Possibly with a sbc as I got one collecting dust. But I really love that buick odd fire, but getting parts is worst than a ford 200. What would you guys to in this case, hopefully this post is allowed since it's a oddball engen. Thanks for your time and help.
Lazy JW
FSP Moderator
Re: Heep of a jeep
Post #2 by Lazy JW » Fri Dec 29, 2017 3:34 pm
My Bro-in-law put a GM 4.3 Liter V6 in an early Willys pickup; that was a pretty sweet setup (for a bent engine).
"The White OX" 1974 F-350 300-6, Stock single exhaust, Carter YF, T-18A, Dana70 w/4.11, Flatbed dually w/dump bed. "Where no oxen are, the crib is clean, but much increase is by the strength of the ox" (Proverbs 14:4)
B RON CO
Re: Heep of a jeep
Post #3 by B RON CO » Sat Dec 30, 2017 9:23 am
Hi, Ford front axles drive from the left side, and GM drives from the right side, so that should be a factor in the decision.
Did you blow the tranny, or just the clutch?
If the Jeep is high millage and worn out you may have to change everything.
See what the Jeep guys are using for a popular and easy swap.
Good luck
1966 Ford Mustang - 289 V8
64-5mustang
Re: Heep of a jeep
Post #4 by 64-5mustang » Sat Dec 30, 2017 5:05 pm
It's a trans broke the counter shaft and impute gear second gear and sent metal through everything else. Sadly with the Buick engen thers no easy simple swap.
