2018 Contributors:
Anything I Should Know?
StarDiero75
Post #1 by StarDiero75 » Sat Mar 03, 2018 6:42 pm
Howdy guys,
After a month of dealing with the clutch and transmission, im about to get the car back on the road. Im just waiting on the new tranny bracket in the mail, any day now.
Is there anything i should know or check before starting the beast? I installed a 78 Fairmont clutch, i have the 67 TO bearing in and hooked up correctly, the 67 bell all cleaned and torqued down, the rebuilt never been used tranny torqued to the bell and filled with tranny fluid, and brand new engine and trans mounts. Just waiting on the bracket so i can install the new trans mount in it. I have the boot for the bell which ill install when i get back under to put the mount in.
Let me know if there is anything special besides setting the clutch pedal that i should do before starting the car. Im kinda nervous, this has been the biggest job ive done yet, and has taken me a month due to school and ordering parts.
This is a 65 Ranchero 200, 65 3.03 tranny
Thanks guys,
Ryan
--1965 Ranchero w/1966 200 and 3.03 column shift, 8" rear 2.8 (Yes I know the gearing sucks), 1968 1.08 Autolite 2100 with VI adapter, CRT Performance HEI.
wsa111
FSP Moderator
Re: Anything I Should Know?
Post #2 by wsa111 » Sat Mar 03, 2018 8:48 pm
Ryan, get it on the road & then you can go from there. Your CRT dist. needs some work when you get some $$'s to spend.
You should be very satisfied with the end results.
67 mustang,C-4, with mod. 80 hd, custom 500 cfm carb with annular boosters, hooker headers, dual exh.-X pipe, flowmaster mufflers, DSII dist. MSD-6al & MSD Blaster 3 Coil. Engine 205" .030" over with offset ground crank & 1.65 roller rockers. 9.5 comp., Isky 262 cam.
StarDiero75
Post #3 by StarDiero75 » Sun Mar 04, 2018 1:09 am
wsa111 wrote:Ryan, get it on the road & then you can go from there. Your CRT dist. needs some work when you get some $$'s to spend.
Good good. Haha, i always figure you'd say something. Are they really that out of wack? Mine drives alright. Would i notice a huge power change if i did have you recurve it?
Also im recommending you on the Studebaker forums when it comes to curving distributors, thats ok, right? You dont just do Fords, right? I go one there and read around looking for stuff about my Lark.
chad
Post #4 by chad » Sun Mar 04, 2018 1:28 am
StarDiero75 wrote:Is there anything i should know or check before starting the beast?...
Let me know if there is anything special besides setting the clutch pedal that i should do before starting the car...
This is a 65 Ranchero 200, 65 3.03 tran...
Thanks guys,
Ryan
other than making sure it shifts, then ck linkage is correct, & U-joints, yoke'n driveshaft all in same alignment as B4 I'd say take it easy getting up 2 speed'n trompin on the gas peddle till ur sure no bad vibes...
We'll all wait till we get the word - then :beer:
Post #5 by bubba22349 » Sun Mar 04, 2018 8:32 am
StarDiero75 wrote:Howdy guys,
Thanks guys,
Ryan
There isn't anything special that needs to be done if everthing is bolted in or installed correctly, plus trans filled with correct gear oil, speedometer and emergency brake linkage etc. As far as the clutch pedal setting your looking for about 3/4 inch minimum (Max is about 1 1/2 inches I set mine to the minimum) of free travel in the clutch pedal before the throwout bearing begins to contact the pressure plates fingers / diafram. After that then try it out and see how it all works. Good luck :thumbup: :nod:
wsa111
FSP Moderator
Post #6 by wsa111 » Sun Mar 04, 2018 3:13 pm
You would be able to notice the improvement.
I've done Studebakers many years ago. Would need a photo of one to refresh my memory.
StarDiero75
Post #7 by StarDiero75 » Sun Mar 04, 2018 3:15 pm
Thanks guys,
Ryan
Do i use a large ruler to measure the free travel?
Thanks,
Ryan
StarDiero75
Post #8 by StarDiero75 » Sun Mar 04, 2018 3:18 pm
Thanks guys,
Ryan
Will do!
Ill let you all know how it goes!
StarDiero75
Post #9 by StarDiero75 » Sun Mar 04, 2018 3:22 pm
Ok sick! I might look into that closer to summer. I need to keep this thing driving for awhile longer. If i had a backup one then i wouldnt worry.
How much do yoy charge to rebuild a dizzy? I have the one i pulled out of it, itd be nice to have a backup if need be. Im not sure if its a loadomatic or a usual dual advance. I ran a carb with a spark valve and without one and it didnt seem to make a difference haha
Im only mentioning you in respect to setting curves and if they need a new HEI dustributor recurved or the super hard gear replaced, stuff like that.
Thanks!
Ryan
Post #10 by bubba22349 » Sun Mar 04, 2018 6:48 pm
Thanks guys,
Ryan
Thanks,
Ryan
Sure you can use a ruler! :thumbup: :nod:
StarDiero75
Post #11 by StarDiero75 » Sun Mar 04, 2018 10:19 pm
bubba22349 wrote:
Thanks,
Ryan
Awesome! Thanks man!!
