2018 Contributors:
"New" Carb Question
65_Stang_170
"New" Carb Question
Post #1 by 65_Stang_170 » Mon Mar 05, 2018 12:07 pm
Howdy Y'all!
I recently purchased a '69 250 (large log), and stripped all of the accessories off of it. I am planning on using the Autolite 1101 and the distributor that I pulled off of the block on my '66 170 (small log). I have a couple questions:
Obviously it's not a straight bolt on for the carbs because of the large log -> small log move. I've attached a photo for reference. I've also attached a picture of the 170's intake.
Will this adapter from VI work for my application? In the description it says for a Carter 1v... Is the bolt pattern the same as the 1101? Also, what are order/ship times from VI?
https://www.vintageinlines.com/product- ... -small-log
Also, I didn't see it until last night: Am I missing the venturi insert thing on the 1101? (picture attached) My 1100's venturi has a 'red' hue to it. If I am missing it, how much of a difference will it make if I don't have it?
Thanks in advance!
1965 Mustang Coupe - 170 I6, 3.03 Manual Transmission, Autolite 1101 Carb
No Upgrades at this time.
65_Stang_170
Re: "New" Carb Question
Post #2 by 65_Stang_170 » Mon Mar 05, 2018 12:11 pm
Also, I am missing the plastic piece circled in the attached picture (which I borrowed from 65 Mustang's post). Any thoughts on where to get one? My 1100 does not have that piece, so I can't grab it from there.
Thanks!
CZLN6
Post #3 by CZLN6 » Mon Mar 05, 2018 12:58 pm
Howdy Stang170:
Hmmm. I may be confused. Are you planning to swap the '69 1101 carb and distributor to your '65 170? If so, you have several options. The simplist is to slot the mounting holes on the base of the 1101 to fit your 170 carb adapter and flare the inside edge of the adapter to allow the larger 1101 butterfly to open. The adapter is is made of soft metal and can be filed with a rounded file.
Option 2 is to use the 1101 adapter and slot the mounting holes that mount it to the 170 log.
I think the VI adapter would take some modifying to mate to the 170 log also.
The venturi on the 1101 looks normal. It's unlikely that the carb would work without the plastic venturi insert. The reddish hue on your 170 1100 is probably due to the gas you are using, or an additive.
If I missed something please set me straight.
65_Stang_170
Post #4 by 65_Stang_170 » Mon Mar 05, 2018 1:25 pm
CZLN6 wrote:Howdy Stang170:
Yes, I am planning on swapping the '69 1101 and distributor onto my 170 (it's a '66 block).
Option 1: will it matter if the base of the carb extends off (overhangs) the 170 carb adapter? The bolts line up perfectly, the carb is just much larger than the adaptor, and the butterfly can't open (can be flared as you suggested).
Option 2: I don't think this would quite be possible (I'll check/measure when I get home). I think the mounting holes would end up in the carb mounting surface.
The VI adapter say from large 1V carb to small log, so I thought that would work (unless it is actually for Carter 1V only). I shot an email inquiring about my specific set up, so we'll see what comes back.
Thanks for the info!
65_Stang_170
Post #5 by 65_Stang_170 » Wed Mar 07, 2018 12:18 pm
Does anybody have experience with the Large carb to small log 1V adapter from Vintage Inlines?
Thanks!
Econoline
Post #6 by Econoline » Wed Mar 07, 2018 9:54 pm
Just buy it. It looks like you have the orientation adapter, that's the hard one to find. Better yet find a good RBS or YF(A) and use that. I don't have that plastic bit, but you might try and get ahold of Mike's carb @ 888 689-9758
It ain't gonna fix itself
65_Stang_170
Update: Re: "New" Carb Question
Post #7 by 65_Stang_170 » Sun Mar 25, 2018 7:10 pm
I received the Large 1V to small log adapter, and it was not a direct bolt on for the autolite 1101 (it was advertised for a carter carb). However, I was able to widen the holes on the base of the carb to make it fit. Now to find or make that pesky plastic piece for the choke...
Post #8 by bubba22349 » Sun Mar 25, 2018 7:50 pm
In the above photo it looks like you already have two original factory Autolite carb to head adapters (early and late) I would just use the late 1969 one with your 1101 carb should be an easy to fit. Good luck :thumbup: :nod:
chad
final pieces
Post #9 by chad » Sun Mar 25, 2018 9:14 pm
yeah, that plastic's not easy. How bout wrkin some alu bar stock?
Users browsing this forum: No registered users and 22 guests
