Fuel starvation going uphill
dulcimerbob
Post #1 by dulcimerbob » Fri Mar 09, 2018 4:35 pm
My 62 sedan delivery starts surging real bad up steep grades and eventually die. On level road runs fine . Any ideas ?
Re: Fuel starvation going uphill
Post #2 by bubba22349 » Fri Mar 09, 2018 6:54 pm
:hmmm: sounds like you don't have enough fuel volume, is the fuel pump older? Try doing a fuel volume test to see how well the fuel pump is doing. Good luck :thumbup: :nod:
B RON CO
Post #3 by B RON CO » Sun Mar 11, 2018 9:35 am
Hi, X2 surging under load means you are not getting enough fuel. Could be the fuel pump, filter, float setting, etc. Good luck
1966 Ford Mustang - 289 V8
wsa111
FSP Moderator
Post #4 by wsa111 » Tue Mar 13, 2018 8:21 pm
If the fuel pump is old, replace it with a new Carter unit.
Check the fuel cap for proper venting.
Sock on fuel sender in tank could be clogged.
Got your homework. 3 items. More fuel to you.
67 mustang,C-4, with mod. 80 hd, custom 500 cfm carb with annular boosters, hooker headers, dual exh.-X pipe, flowmaster mufflers, DSII dist. MSD-6425CL & MSD-Blaster 8252 Coil. Engine 205" .030" over with offset ground crank & 1.65 roller rockers. 9.5 comp., Isky 262 cam.
