Almost change of wardrobe time
woodbutcher
Post #1 by woodbutcher » Fri May 11, 2018 11:15 pm
:shock: On wensday.Coming home that morning the rim of my steering wheel came loose from two of the spokes(after market wheel).It was at least 15 years old.Welds(if .you could call them that).They were about 1/8" wide,and barely contacting the rim of the wheel.Soooooooooo,if you are using an aftermarket wheel,if possible,check the welds.The wheel that I have is repairable,and when I have the time I will take the wood off and get it miged or tiged.Just glad I had just dropped off my friend coming home from the grocery store.She for sure would have wet herself.
Good luck.Have fun.Be safe.
Leo
Otto von Bismarck
Lazy JW
FSP Moderator
Re: Almost change of wardrobe time
Post #2 by Lazy JW » Mon May 14, 2018 12:10 pm
Yikes! Glad you are safe :nod:
"The White OX" 1974 F-350 300-6, Stock single exhaust, Carter YF, T-18A, Dana70 w/4.11, Flatbed dually w/dump bed. "Where no oxen are, the crib is clean, but much increase is by the strength of the ox" (Proverbs 14:4)
woodbutcher
Post #3 by woodbutcher » Mon May 14, 2018 2:30 pm
:D Hi JW.Let`s just say it was an adventure that I don`t want to repeat. :shock:
Leo
Otto von Bismarck
Post #4 by bubba22349 » Mon May 14, 2018 6:53 pm
:shock: wow Woodbutcher that will really spice up your life! :bang: Good luck :thumbup: :nod:
woodbutcher
Post #5 by woodbutcher » Tue May 15, 2018 8:00 am
:arg: Can you say"Pucker Factor"?.I was only going about 25 MPH when I hit a rough patch of pavement when it happened.Thank goodness.
Leo
Otto von Bismarck
