New dual exhaust headers: choke heat riser tube?
OakR8ders12
Post #1 by OakR8ders12 » Thu Jun 14, 2018 3:06 pm
Had dual exhaust headers installed. Now my choke heat riser tube has no where to attach to the engine. Any nice looking, easy and inexpensive suggestions? thanks
wsa111
FSP Moderator
Re: New dual exhaust headers: choke heat riser tube?
Post #2 by wsa111 » Thu Jun 14, 2018 3:15 pm
Depending on your carburetor, replace the thermostat with an electric choke. Kits are available to clamp a new tube from the choke to the header pipe.
chad
Post #3 by chad » Thu Jun 14, 2018 3:25 pm
OakR8ders12 wrote:Had dual exhaust headers installed. Now my choke heat riser tube has no where to attach to the engine. Any nice looking, easy and inexpensive suggestions? thanks
don't need much, just lay it down on a tube or (dependin on length) wrap it around for more contact/heat.
Ck that the bimetal 'coil spring' is hooked to the butterfly's tab inside the blk bakelite 'pill box' at that end of the carb. U can do that easiest by diddelin the butterfly - if it goes easy and flops back (closed) it's probably hooked.
DannyG
Post #4 by DannyG » Thu Jun 14, 2018 9:48 pm
Question on that hot air choke tube, should the lower end be left open> Or should I pinch it closed ?
Vacuum leak if open versus doesn't flow hot air when closed ?
DannyG
C8 block, .040 over, zero decked. Forged Racetec pistons , D7 large log head .9:4 compression, CSC 264-112 cam going in a '65 Mustang one day...
Post #5 by bubba22349 » Thu Jun 14, 2018 10:10 pm
:shock: yes if you want the choke to work as it was designed too, then the choke stove needs to be open so as to draw warm air into the choke housing! Plus that very small vaccum leak is needed to be able to do this. Good luck :thumbup: :nod:
wsa111
FSP Moderator
Post #6 by wsa111 » Thu Jun 14, 2018 10:21 pm
What carburetor are you running???? Certain carbs can be converted to an electric replacement.
Econoline
Post #7 by Econoline » Thu Jun 14, 2018 11:13 pm
Electric chokes are great but they do have a drawback, they choke a little bit when it isn't needed in the summer and after parking it for a little bit. But the easy work around is to adjust it to lean in the summer. They aren't connected in an analog way like the climatic chokes. They kind of are b/c they still feel the heat and work in the same way but there is a difference. They don't get the heat as directly so they will close a bit when it isn't needed when the power is gone.
It ain't gonna fix itself
chad
Post #8 by chad » Fri Jun 15, 2018 12:04 am
DannyG wrote:Question on that hot air choke tube, should the lower end be left open> Or should I pinch it closed ?
DannyG
if U have the carb I think U o it's not even close to the throat, venturi, etc so no "vacuum leak" at all.
The only draw back is it allows ambient air (may have 'road dust') into the combustion chamber - that gets incinerated, & a lill in the carb itself.
Worried?
Follow up w/Seth's plan - wire up an ele choke (offa the stator lug of the alternator).
DannyG
Post #9 by DannyG » Fri Jun 15, 2018 9:23 am
"What carburetor are you running???? Certain carbs can be converted to an electric replacement."
Going with the Autolite 1101 and the stainless steel headers. I plan on wrapping the headers too, and wondered if I needed to let the end of the choke tube hang out in the atmosphere ?
wsa111
FSP Moderator
Post #10 by wsa111 » Fri Jun 15, 2018 12:51 pm
DannyG
Worried?
Chad if you have an oem choke designed for 9 volts via stator hookup. I had a 1980 F150 & that choke thermostat used stator voltage.
However if you are running a Holley carb or Holley choke thermostat you need full battery voltage to make it open properly.
If the choke housing is not warped a Holley electric choke cover will fit. Need 12V.
All chokes, electric or exhaust heat need airflow to keep from burning up. Holley chokes have a screw on fitting with a small mesh wire screen to block dirt. OEM style take fresh filtered air from the air cleaner base.
chad
Post #11 by chad » Fri Jun 15, 2018 8:01 pm
"... if you are running a Holley carb or Holley choke thermostat you need full battery voltage to make it open properly...."
Thanks, Bill !
Users browsing this forum: No registered users and 32 guests
