2018 Contributors:
Needed Duraspark Ignition wiring diagram or info
CoupeBoy
Post #1 by CoupeBoy » Fri Jul 13, 2018 1:14 pm
I'm trying to find information on the 'right way' to wire up a yellow strain Duraspark II ignition box.
This box would have been used in 79-81 Mustangs with the carb turbo 2.3L i4 cars.
I can find the diagrams that work for blue and red, but not yellow.
I'm working on an old school method for how to retard timing underboost.
The normal blue/red boxes have a built in 5 degrees of retard when the white wire is engergized, the yellow has another 2 degrees via the additional plug.
So what am I actually trying to find?
This is the 'normal' wiring that is easy to find.
White Wire - Start Terminal
Red Wire - Run Terminal - 12v Battery Positive through Ignition Switch
Purple Wire - Input Signal Negative from Ignition Pick-up Coil
Orange Wire - Input Signal Positive from Pick-up Coil
Green Wire - Ignition Coil Negative Terminal
Black Wire - Battery Negative - Ground from Distributor
These extra wires, I'm trying to track down their intended use and voltages. (black seems obvious)
Yellow Wire - Run Retard Program Line Return
Black Wire - Run Retard Ground Terminal
Brown Wire - Run Retard Program Line
Am I overthinking this?
Do I just hook yellow to one pin on a pressure switch and the brown to the other?
1970 170/C4
1967 200/C4
1975 250/flexplate
1975 300/flywheel
Re: Needed Duraspark Ignition wiring diagram or info
Post #2 by bubba22349 » Sat Jul 14, 2018 12:14 pm
In the below link you will find the wiring diagrams (in PDF) first three are for the 1979, 1980, & 1981 Ford Mustang's should also cover those years of the Mercury Capri's too. Good luck on your project :thumbup: :nod:
http://vb.foureyedpride.com/showthread. ... 986-in-PDF
CoupeBoy
Post #3 by CoupeBoy » Mon Jul 16, 2018 10:50 am
I left out a few details.. I had looked at those diagrams already, and they are only good for NON-turbo cars.
Here's the pic for the 1980 ignition where it only shows 2 connectors, yellow strain has 3.
Here's the rest of what I've looked at, I left it off because I thought it was getting too long.
After picking up the GM draw through turbo setup at a swap meet, I started thinking about timing control. And I figured that somewhere along the line somebody must have figured out manual timing control. And I found that Ford did.. from 1979-1981 the 2.3L turbo cars were carburated and used a 'yellow strain' Duraspark module.
Before I found the Ford info, I had already found GM 5-pin HEI info.
This shows how to wire a pressure switch to trigger the timing retard.
http://www.instructables.com/id/Dirt-ch ... ed-engine/
More digging turned up information on the Ford system, but not quite everything.
https://www.fordmuscleforums.com/all-fo ... ction.html
Based on the Ford Muscle link, I found a Wells F110 module on Amazon and ordered it.
Finding Blue Strain wiring is easy, same as Red strain. (attached)
But yellow strain apparently somehow skipped being documented.
I've checked Autozone wiring diagrams, they conveniently skip the 79-81 turbo models
https://www.autozone.com/repairguides/S ... 5280065bf4
I found a thread on FourEyedPride that shows wiring diagrams, but not the turbo ones.
Post #4 by xctasy » Wed Jul 18, 2018 7:10 pm
You can apply power to the white wire and watch your timing step back on any Duraspark II, Blue, Yellow or Duraspark III Brown
Yellow Strain is both Duraspark II just makes it easier to externally and additionally pull out spark advance via the Distributor Modulation Valve (DMV) or the altitude-compensating spark retard. DSIII with Brown Strain relief accesses the BMAP sensor, similar to the later TFI MAP sensor on EECIV Fords.
You can use the old white wire to do it.
All Duraspark II/III's have a built in 5 degree retard on start. The Yellow Strain Refief has an additional 3-pin wiring connector, and two Yellow strain relief bushing's. The Duraspark II control module with a Blue strain relief bushing has one 4-pin connector and one 2-pin connector.
viewtopic.php?f=2&t=78628
Lazy JW wrote:If you are using a stock DuraSpark 2 ignition, verify that the ignition is receiving the signal to retard the ignition while cranking to start. IIRC it is the white wire that needs to have 12 volts during cranking; this retards the spark ≈ 5° for easier cranking.
Former user here, Mark P, described that the usefull Yellow Strain Duraspark Module, and the DSIII Brown has a BMAP interface to dial in or out advance, via what was the IGN pink wire. That normally whent to the Wht I wire, but there are various wiring diagrams on the web, and according to PSIG at fordmucle forum, ones called "conversion wiring" may have issues.
For example, one diagram uses the starter relay "I" terminal for just the white wire for start retard (that's OK), but powers the module from the coil wire after the resistor (not OK). That forces the module to run on fluctuating voltage averaging 6 to 9 volts.
Additionally, the Duraspark II replacements vary.
Old convention is is
Red-
Wht-
Grn-
Blk-
Pur-
Or
and the new is
Gr-
Blk-
Or-
Pur-
Red-
Wht
Yellow is best found used, and to track down a
(Each from the outside edge)
Newer replacements have moved away from the stock 1977-1984 Duraspark II wiring protocol, so it can be a little hard to locate a working diagram of the Duraspark II/III Yellow Strain Relief box.
Any Central EFi 5.0 (1980-1985) or Feedback Carb( VV2700/VV7200) can aditionally be Duraspark III and EECIII equiped.
The little 2.3 has a feedback Holley Weber 6500 for CA or Hi Altitude areas, or in Carb Turbo applications.
or some other Fords have the Yellow Strain Relief, its not just a Turbo Carb 2.3 thing. AMC's 258 and some 304's used he Yellow Strain relief for two years.
http://vb.foureyedpride.com/showthread. ... odule-Info
http://vb.foureyedpride.com/showthread. ... &p=1143121
[QUOTE=8T6 SVO;1142813]I've got what appears to be a early 2.3 turbo motor ignition module with solenoid.
Can anyone tell me specifically what this part is?
There is a tag with the numbers EOSE-CIA and the module has a
D8AE-12A244-AA on it.
The part looks to be never used, but stored poorly for many years. I have no use for it and thought maybe a Pace car or Cobra car some where might have a use for it.
So - I'm trying to ID it, and get it to the right person.
Thanks in advance!
[/QUOTE]
[QUOTE=gr79;1143121]The box looks to be a DY-237. There were AA and AB (237A) versions.
Both have 3 connectors, 2 yellow strain reliefs, 3 wire 3rd plug.
For turbo, non-turbo apps.
Switch setup shown modifies spark (retard?), non turbo, car/truck.
Was something like for high altitude, carb. Exact engines it was used with-??
Turbos had additional switches similar to one shown.[/QUOTE]
Post #5 by xctasy » Wed Jul 18, 2018 7:37 pm
MCU controlls some of the system, the Duraspark II with Yellow Grommet is self correcting from the ignition on start up, then the advance under boost and DMV
[QUOTE=Dean_T;1737543] Just for reference, this is what the ECU looked like in a 3.8L V6 '82 Cougar wagon:
You can see what shape and size the ECU connector is.
Image[/QUOTE]
[QUOTE=xctasy]Read
AND Jeeps partly Ford inspired MCU
Image[/QUOTE]
Post #6 by xctasy » Thu Jul 19, 2018 3:07 am
Carb Turbo 79 and 80 wise, see this
"For-reference-79-and-80-Turbo-Carburetor-Jet-Sizes-ID-numbers-etc"
The visual guts of the yellow grommet Duraspark ii for 1980 Feedback CA model is here.
"http://vb.foureyedpride.com/showthread.php?92600-Carb-Turbo-M81-Mclaren-ready-to-start-after-15-years!"
http://vb.foureyedpride.com/showthread. ... r-15-years!
(10 pages)
"gr79]Fooling with the waste gate hose can get 5+ easily. Mix in some racing fuel to be on the safe side.
Definite noticeable increase of power at 7#, about as high as i want to go.
On my carb 2.3T [1979], there is a check valve in that hose that affects how the gate works.
Also uses a DY 237A ignition module which retards timing in relation to manifold signal.
Has 3 harness connectors.
The turbo engine sensor array on the fender apron near the washer fluid tank does the timing map.
Noticed in the [1980 CA Mclaren ] M81 pic the item in the engine bay near there right were the array is on mine.
Ig box mounted higher?[/quote]
http://vb.foureyedpride.com/showthread. ... umbers-etc
Although vaccuum line related, this will help some.
"1979-2-3-turbo-vacuum-lines"
http://vb.foureyedpride.com/showthread. ... cuum-lines
[quote]I think Diagram 22 of 107 might be the 1979 CA one.
9-2R-R11
http://myzephyrs.com/VAC_2.3/9-2R-R11.html
A CA or CO 1979 stickers differs to the other 48 states 1979 cars. [/quote]
07-03-2018, 05:43 PM #24
[quote="Meela wrote:
Let me add my experience, I've had half a year of adjustments Mustang 2.3 turbo
Intake (metal) line connected to hose with clamps:
#1 RNR to Spark retard switches (when is boost, the spark is retarded) - (original)
#4 RNR goes to T splitter. From this T to carb (direct to F port (power-valve) and via check valve to Venturi port), and second part of T goes accross check valve to wastegate (primary port) across check valve control that to wastegate goes positive pressure only (not vacuum).
Secondary port of wastegate can be connected to MAN PLN or let it open to Atmosphere, but not caped!
(modified)
Post #7 by xctasy » Thu Jul 19, 2018 3:44 am
the baseline EVTM and VECI diagram (what gr79 listed is in fact post #14& #15 combined; it's great advice!).
http://vb.foureyedpride.com/showthread. ... ars!/page8
Before 1981, the car was the EVTM and VECI diagram
gr79 wrote:The 1979 Mustang/Capri EVTM has no detailed turbo vac schematics.
1979 Ford Service Highlights, 2.3L Turbocharger handbook does
Pic of hard to find handbook: https://www.google.com/search?q=ford+2.3+turbo+vacuum+routing&biw=1152&bih=715&source=lnms&tbm=isch&sa=X&ved=0ahUKEwiQquf95qPSAhXGOSYKHU4RBa04ChD8BQgGKAE#tbm=isch&q=ford+service+hilights+2.3l&imgrc=nVqw0RYIRxd9lM:
Blurry pic, broken link? the real deal on page 36: https://www.google.com/search?q=carb+turbo+vacuum+diagrams+four+eyed+pride&biw=1140&bih=677&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEwiBrYut2KPSAhWG6iYKHSf4B0kQsAQIHA#imgrc=0G1o-6mi6Rv5LM:
Calibration code for 1979 49 state Mustang/Capri 2.3L turbo is 9-2E-R93
Calif is 9-2R-R93
Link to copy below. Almost exact routing and parts were used in Fairmont/Zepher 2.3t's.
http://myzephyrs.com/VAC_2.3/9-2E-R0.html
Decoding of most abbrev in diagram, post #13 : http://vb.foureyedpride.com/showthread.php?65173-1979-2-3-turbo-Engine-Pics-required-please!
And:
http://myzephyrs.com/vac_part_name.htm
Sellis1012 wrote:these are the two primary things you need. You might have the schematic under your hood that you'll want to butt up against this one. You need to study the schematic, then study and figure out what each piece of the puzzle is from the abbreviations. If you have a question about what a particular piece is, take a picture, post it up and I will be able to tell you what it is. I pulled out some skills from basic electronics in the Air Force and traced out all the lines with different colored pencils. So you will want to print these out. I can e-mail you the pictures and if you can put them on photoshop you can make them bigger. They are quite clear on photoshop. SHould work in Word as well. The cut off abbreviation is VVVAC-Vent Valve Vacuum.
RNR#1 and 4 are the metal vacuum lines.
MAN PLNM is your vacuum tree at the front of your engine.
SPK RET is the set of switches by your washer res.
[QUOTE=Sellis1012]Please notice on the schematic where it says "front of engine". That is accurate. All the pieces should be in close vicinity to where they are on the schematic.[/QUOTE]
The 2.3 Carb turbo CA or 1980 2.3 Carb Turbo MCU system brain box, I've not been able to identify it on any schematic or picture yet.
Post #8 by xctasy » Sun Jul 22, 2018 8:37 am
Confirming that the Yellow Strain Relief Durasaprk II module also controls the inputs from some of the five potential Solendoids; it operates from the five Null Knobs, or potentailly Six (6) sensor controlls that might present on a 2.3 Turbo carb engine.
Specifically, the 2.3 Carb Turbo is not a Feedback Carb 2.3 engine, has no Oxygen Sensor, and is not MCU.
The five structures of the six possible are:-
Green (RNR#1) and Orange (RNR#4) on the Top plate
Then Pink, Pink (first two) (SPARK RETARD) and the last (the 3rd) is also spark control. Pink, Pink, Yellow on the bottom Bottom plate.
Yellow is a factory set Solenoid.
Again, IIRC, there is an additional possibly Red "Sol V" for A/C Throttle Kicker to add 50 rpm to the idle speed, but its seperate from the Yellow Strain Relief Duraspark SII.
Here is an M81 engine with A/C, turbo 2.3 Carb engine in Califonia emissions with the Twin Cataylst engine standard on all 1980 Turbo's.
Gere are the VECI schematic Solenoids highlighted.
Everything is 9 or 12 reference voltage (12 volt is battery reference, so it can be as high as 14.9 volts, or as low as 9). MCU, EEC 1, II and III used the higher voltage to control inputs to the Duraspark II or III, or the MCU or EEC unit.
It was only The EECIV and later than 1984 stuff that had the 5 volt reference voltage. The early stuff is nigh on bullet proof, so your free to experiment.
So experiement with the inputs to the pin plugs, and measure your actual advance. You won't destroy an Yellow DSII.
Post #9 by xctasy » Sun Jul 22, 2018 9:27 am
gr79 wrote:As far is i can figure, control assy pictured controls timing, red engine light,flasher and buzzer, green turbo light.
The dash lights are triggered by pre-set boost values sensed by the manifold pressure switches thru vacuum connections.
I believe the top pair of switches are for the lights,etc,
bottom pair for ignition timing control.
Each pair consists of one high and one low limit switch.
Assy. is connected electrically to one plug of the 3 plug DY-237-A ignition module (yellow strain)
Image[/quote]
Post #10 by xctasy » Sun Jul 22, 2018 9:48 am
Very importantly, the Three Pin Plug wires have been changed after the 1979 model year; D8 and D9 color codes vary.
The module is listed as a Feedback carb option for 1980 250 YFA equiped Granada passenger cars, as well as many others, 10 pages long in fact.
Post #11 by xctasy » Fri Jul 27, 2018 6:19 am
Just confirming from gr79 and m81mclaren that no carb turbo 2.3 Fords were feedback, so no need for MCU to trim air fuel ratio.
So your free to experiment as discussed.
gr79 wrote:......
Module:
My 79 2.3T uses a Motorcraft DY-237-A or D9AZ-12A199C module assy.
Two yellow strain reliefs on side. One has 2 wires, one has 4.
No other connections. Two black harness connectors.
Connectors, wire codes to module:
One 2 wire (pink, white), one 4 wire (green, orange, purple, black/green stripe).
The 2 wire connects to the sensors. The 4 wire connects to the distributor.
Only other turbo boost related item under hood is the two level sensor assy on fender.
For red over boost warning light/buzzer, green TURBO light, ignition timing retard under boost.
The warning modules, buzzers, are behind ps dash.....
