2018 Contributors:
Key Switch Issues
philford
Key Switch Issues
Post #1 by philford » Sat Feb 09, 2019 11:02 pm
I have an 88 E150 van .
I got in when it was cold and frozen and the chrome thing with ears around the ignition key wouldn't turn.
I sprayed silicone in there and got it to turn with a little force so I could get to work.
now it works but feels a bit stiff. It doesn't want to spring back properly.
I assume I have to pull the steering wheel and that there is probably some trick to getting the ignition switch apart? how do I get in there?
should I order a new ignition switch? is this a common issue?
thanks !
Phil
Re: Key Switch Issues
Post #2 by bubba22349 » Sun Feb 10, 2019 12:04 am
Yes it's a common issue because they wear out, had to replace key lock assembly on my 1994 F150 pickup too. Yes you will need to get a new lock unit. You don't need to remove the steering wheel there is a pin that holds the key lock in the column. Good luck :thumbup: :nod:
Shorty
Post #3 by Shorty » Sun Feb 10, 2019 9:41 pm
I had a similar problem on my 85, in addition to removing the key/lock assembly I also dropped the steering column and lubricated the switch that is operated by a push rod from the key/lock. After a good clean up of both parts and some lube it worked as new with no new parts needed.
85 F150 on 78 bronco frame C6 np205 welded dana44 front, trussed posi nine inch rear. EFI exhaust manifolds into one 2 1/2" rolls on 35x12.5x15 Maxxis Trepador.
philford
Post #4 by philford » Fri Mar 22, 2019 5:13 pm
I found an online video that shows how to take the switch out which I have not yet.
I think there is a part that locks the steering wheel , it can be removed and then the steering lock wont' work but it isn't a necessary thing so far as I see, then probably no switch needed.
