1960 Ranchero leaf spring interchange
64 200 ranchero
Post #1 by 64 200 ranchero » Wed Feb 13, 2019 1:41 am
I recently went with larger wheels and tires and now have a tire rubbing issue. I'm currently on stock springs with 1.5" lowering blocks and believe that it is rubbing due to the sloppy side movement caused by the blocks. I would like to find some springs that will drop the rear without using blocks. I remember that someone had a leaf spring interchange list on a post a while back. I don't mind if I have to relocate the rear spring perches.
60 ford ranchero daily driver. 200 tri power, modified c4 trans, ds2 distributor, msd programable 6al2, weber ict's, 8" rear end with full spool, 3.80 gears, 245 tires, CI dual out header, Dynomax muffler, 114hp shot wet nitrous kit. JE Forged pistons, 280 110lc cam, around 11-1 compression.
frozenrabbit
Re: 1960 Ranchero leaf spring interchange
Post #2 by frozenrabbit » Wed Feb 13, 2019 4:57 pm
Are you running Ranchero springs or sedan/coupe springs?
Sedan/coupe springs have less arch, but I don't know the height difference. I believe there is also a different in spring rating.
I've got a '62 I'm working on, Maverick 8" and sedan springs, but I haven't had it on the ground yet, replacing previous hack quality installed lower quarters, and stripping the underside.
I've got a pair of 1" blocks and 2" blocks, with 1" offset to move the axle back 1". To me, the rear axle on Falcons and Rancheros is set too far forward in the rear wheel arches. The blocks give a little more forward clearance for the tire. That changes the drive shaft length, but I need a new one any way due to the 8" and 3.03 trans swap I've done.
Maybe go with a reverse eye spring or have yours back-arched?
If you have a reputable spring shop close to you, they can make just about any dimension/rating spring you would want.
Users browsing this forum: No registered users and 13 guests
