camshaft schneider 248-56
sdiesel
Post #1 by sdiesel » Thu Mar 14, 2019 12:51 am
paul, this cam is my current cam with a rebuilders head.
with the Jr head, will I be better advised to change cam?
the unsightly mess I will make if I don't begin to sync parts pretty soon, before i begin making real power, will lead to my demise.
the block has, best I can remember the d -dish hyper rebuilders , likely cast iron rings
.60 overbore, we did not zero deck.
pmuller9
Re: camshaft schneider 248-56
Post #2 by pmuller9 » Thu Mar 14, 2019 9:16 am
It looks like your compression ratio might be around 8.4 with a 76cc carb head.
The JR head would change the CR to 9.1
A Schneider 140H (13912) .496”/.496” 220/220 280/280 110deg would give you a wide power band including better off idle torque and keep you from having to use premium pump gas.
The Crower 284HDP (19205) .509”/.517” 220/222 284/290 110deg will also work very well.
sdiesel
Post #3 by sdiesel » Thu Mar 14, 2019 11:20 am
Thx paul.
I failed to mention this engine is in an 8000# truck with a 5 speed.
410 gearing.
chang anything ??
pmuller9
Post #4 by pmuller9 » Thu Mar 14, 2019 11:33 am
No
Because the ports are undersized for the cylinder displacement we see increased torque across the entire rpm range as the intake valve is closed later. (Up to a point)
A ported iron head doesn't have much more port volume than stock.
Last engine had a 232* .050" intake duration and made serious torque from 1200 rpm with a fully ported big valve head.
A 220* intake duration should give you plenty of torque from just above an idle and will supply a lot of power to keep the truck rolling at highway speeds.
sdiesel
Post #5 by sdiesel » Thu Mar 14, 2019 12:05 pm
Thx Paul
I'm going down to their shop here in a few minutes.
dave
sdiesel
Post #6 by sdiesel » Thu Mar 14, 2019 7:41 pm
just to say, Paul thx Fer the input.
jerry was out and I got a word with Kevinno at schneider.
Kevin is usually the shop guy doing the work.
I explained, ,he concurred. and the opinion of his fell right directly in line with the opinion u have expressed herein.
essentially he said "you were right on with ur assessment".
I invited, nearly plead for them to join up to see what was going on here.
perhaps they will and we get another top flite resource at our disposal
BigBlue94
Post #7 by BigBlue94 » Sun Mar 17, 2019 11:32 am
I have the Schneider 140H in my 300 with 9.75 CR and a factory head with big valves. It's a week or so away from firing up.
I was impressed with their service and visual quality of the cam.
1985 Bronco. 300-6, NP435, 4.56 gears, Detroit locker and tru-trac, 4" lift, and 37" swamper tires. 300 has a 4bbl and headers.
Users browsing this forum: No registered users and 26 guests
