Coil Mounting Bracket Change
old28racer
Post #1 by old28racer » Thu May 16, 2019 11:28 pm
I have a 300 inline 6 in my '72 F250 and would like to change the coil mounting bracket from the OEM flat position to a straight up mode as it would be much easier to get to for this "old" man. I have not found a bracket that will do this and mount in the same area. Open to all idea's :bang:
pmuller9
Re: Coil Mounting Bracket Change
Post #2 by pmuller9 » Fri May 17, 2019 12:20 am
You make a channel that fits tightly over the mounting boss on the head and weld it to the back of the stock coil bracket.
old28racer
Post #3 by old28racer » Fri May 17, 2019 1:11 am
Sorry Paul, I am not getting a picture in my some what messed up mind, I am sure you know were I'm coming from. :bang:
pmuller9
Post #4 by pmuller9 » Fri May 17, 2019 1:32 am
OK
In order to get a picture you need to remove the coil from the head to see the mounting boss that is part of the head.
The sides of the boss are not quite parallel so the channel sides that fit over the boss will have side angles that match.
Dr Jay
Post #5 by Dr Jay » Fri May 17, 2019 8:54 am
I need a change there as well.
Blessings,
Dr Jay
1978 F100 Shortie, Lowered front and rear, 300 .030 over, 300 carb head, Clifford, Holley 390
268 Comp Cam, Cloyes, Fuel Inj. exhaust manifolds, MSD 6A, TOD, 9"
old28racer
Post #6 by old28racer » Fri May 17, 2019 10:20 am
Thanks pmuller9, I will see if I can check it out on my 240 head that's on my shop motor build.
BigBlue94
Post #7 by BigBlue94 » Fri May 17, 2019 10:38 am
Like this? 1985 bronco, 300
I no longer need it, as I went HEI. OP, PM me if you want it. Then whoever else, if he passes
old28racer
Post #8 by old28racer » Fri May 17, 2019 1:16 pm
BigBlue94 ---- I'll take it! PM was sent. Thanks
SteveP
Post #9 by SteveP » Fri May 17, 2019 1:34 pm
I have my coil upright in the same location. I just positioned the bracket on the coil and bolted it on.
old28racer
Post #10 by old28racer » Fri May 17, 2019 9:25 pm
BigBlue94 -- I sent a second PM with my address information. I think my PM file was over full and was not sending. Thanks for the bracket.
old28racer
Post #11 by old28racer » Fri May 17, 2019 9:38 pm
In the mean time before I install my pertronix Ignitor, relay & Flame thrower 3 ohm coil I would like to put in new Motorcraft plugs, HI Pro Pertronix plug wires and a new good quality stock style coil. The motor ignition is currently stock with P&C distributor & running the original brown/pink resistor wire. Not sure if the coil needs to be a 1.5 ohm unit? What have you guys used? looking for something in the $20-25 range.
BigBlue94
Post #12 by BigBlue94 » Sat May 18, 2019 6:07 pm
Was at the JY today, and noticed quite a few upright brackets like the one I have. And confirmed my suspicion, that it's an efi square coil bracket with a round clamp added. I think the added round clamp is used for attaching the end pole of a chain link fence to a structure. It works though, and with a little paint, will look great.
old28racer
Post #13 by old28racer » Sat May 18, 2019 6:16 pm
It's going on an old truck, no show truck, just my get around town ride. If it holds the coil vertical I will be happy. Thanks again.
BigBlue94
Post #14 by BigBlue94 » Sat May 18, 2019 6:21 pm
old28racer wrote:It's going on an old truck, no show truck, just my get around town ride. If it holds the coil vertical I will be happy. Thanks again.
You're more than welcome!
I didnt even notice its 'true nature' until I really looked at it, so it's not super janky looking or anything.
sdiesel
Post #15 by sdiesel » Fri May 24, 2019 12:39 am
dr. jay,
ur plug wire set looks beautiful.
lots better than my used 460 spaghetti.
also FWIW, those not using the mech. fuel pump, the TFI coil bracket bolts beautifully to the fuel pump boss , and ideal location, especially if using HEI, trigger, as it sits in perfect proximity to the distributor.
old28racer
Post #16 by old28racer » Sun May 26, 2019 6:32 pm
Well made some modifications to the coil bracket BigBlue94 passed forward to me. Got it in my F250 today, worked out great. Much easier for this old man to get to the coil & connections with it straight up.
Users browsing this forum: No registered users and 13 guests
