Running on 5
Boone2180
New Member
Running on 5
Post #1 by Boone2180 » Sun Jul 07, 2019 10:25 am
Since I'm new to this forum, I'm not sure that I'm posting this in the right spot. I've tried doing a search, but I haven't run across what I'm looking for.
About my truck... it's a 1996 Eddie Bauer regular cab short bed with the Mazda 5 speed. I purchased it 2 weeks ago from a farmer. The truck has about 135k miles. The tires are the wrong size, so my speedometer is off but I will remedy that soon. I've done a full tune up, plugs, wires, rotor and cap. I've also replaced a couple of vacuum lines that were very deteriorated. Yesterday, I took it on a 3 hour round trip. When I got to the halfway point, it felt and sounded like it started on 5 cylinders. I shut it off and after starting it again, it began to clear up. It did it again when I got home. I had just replaced the catalytic converter and full exhaust the day before the trip. I'm just a bit confused and any advice would be great.
68Flareside240
Re: Running on 5
Post #2 by 68Flareside240 » Sun Jul 07, 2019 1:15 pm
Start with the simple things first. Check engine light on? Make sure all of your plug wires are making good contact. Check the plugs. Make sure it’s getting fire.
Mdixon300f100
Re: Running on 5
Post #3 by Mdixon300f100 » Sun Jul 07, 2019 1:29 pm
I’ve had a few spark plugs on cyl 6 loosen up and cause a misfire before in my old truck. It’s important to retorque everything after a few heating cycles to make sure nothing moved.
Boone2180
New Member
Re: Running on 5
Post #4 by Boone2180 » Sun Jul 07, 2019 3:26 pm
So it turns out I had a defective plug wire. The conductor on the #5 plug wasn't crimped on properly. When I pulled the wires to check the plugs, it was attached to the plug. I took it back to the parts store and got it replaced under warranty. It started up smoothly. I won't find our if that took care of the problem until I take it for a drive later in the week. Thanks for the help.
68Flareside240
Re: Running on 5
Post #5 by 68Flareside240 » Sun Jul 07, 2019 5:45 pm
:thumbup: glad you got it figured out. I would bet it gets it fixed.
B RON CO
Re: Running on 5
Post #6 by B RON CO » Wed Jul 10, 2019 4:39 pm
Hi, I save old plug wires and other old parts just in case that happens. It's nice when the part you need is back home. Unfortunately, new parts aren't always good parts.
Good luck
1966 Ford Mustang - 289 V8
Users browsing this forum: No registered users and 16 guests
