Offenhauser DP to Clifford heating difference.
F-250 Restorer
Post #1 by F-250 Restorer » Sun Jul 14, 2019 11:35 am
I changed from a Offy DP to a Cliff. intake. Both have the engine coolant flowing through them. I changed the intake and engine a couple of months ago, so I've been playing with/adjusting the choke to get it right. However, with the Cliff. intake, using the same holley carb as was on the Offy, I find that I have to warm up the engine for five minutes or it wants to die when I try to accelerate. With the Offy there was no problem. Once the engine is warm, it runs well.
Thoughts?
BigBlue94
Re: Offenhauser DP to Clifford heating difference.
Post #2 by BigBlue94 » Sun Jul 14, 2019 7:40 pm
I've never had that problem with my Clifford. As far as I know, the Offy is built to use the factory manifold type of heat, whereas the Clifford has a long water jacket on the bottom of the manifold.
Did you readjust the carb due to the difference of the DP and the open Clifford?
jason832
Post #3 by jason832 » Sun Jul 14, 2019 8:48 pm
I was going to suggest carb tuning as well. My Clifford doesn't seem to make a difference with or without water heat, very small if at all.
Maybe it needs a fast idle?
Users browsing this forum: Firepower354, Soldmy66 and 10 guests
