<<< New Site Update >>>
Holley 5200 carb
- old28racer
- Registered User
Holley 5200 carb
Guy over on the 240/300 site said I might be able to get some real time information on this 2bbl carb. Anyone using one? How is the gas mileage if you stay out of the secondary most of the time?
I am currently running a Holley 2300 350cfm that uses .061 jets & 8.5 power valve. My city mileage is real poor at 6-8 mpg, highway not to bad at 15.5 mpg flat ground at sea level. The motor is a fresh stock rebuild with headers and dual 2 1/2" exhaust. The carb is mounted on a 300 log intake manifold with a 2x1 adapter. The original 1bbl hole has been opened up some, maybe 25-35% but it is still very restrictive.
Bad Day Racing Is Better Than A Day In The Stands
- chad
- Registered User
Holley 5200 carb & potential MPGs ?(?on what?)?
I don't C ur specifications in ur sig (truck? which one? rear gear/transmis?).
And think even if ona 240/300 ci - mi would B in the hi teens to low 20s? but can't say.
For the very low mileage U quote I'd say U have other issues than wrong carb match to motor/weight.
Some of us call that carb the Pinto carb (or Weber 32/36) as that's one of several places it wuz used. Also a Heep 6 (~250/4L).
As I recall 1 other guy tried to run a car carb on his truck (or wuz it U?). U may want to search his thread. I believe he tried different jets & other rebuilds w/o satisfaction.
- old28racer
- Registered User
Re: Holley 5200 carb
3.73 gears, C4 trans, Standard long bed !971 F250, Run around empty 98% of the time. Truck runs great, 19" vacuum, Base timing at 17* btdc, Full on mechanical advance 34* btdc. I will be getting a new wideband AF unit next week to see where the carb/motor are right know.
- Registered User
Chad , do you know if the pinto webber 32/36 is rejetted or stock when used?
- StarDiero75
- Registered User
I done heard about this before. I believe the Holley 5200 and the Weber 32/36 are a little underpowered for the 300. I currently run the weber on my 200 and I'm constantly fiddling with it and i cant ever seem to get the jets right. It runs lean when it should be rich, or rich when it should be lean.
May i ask why you haven't just got a 2bbl or 4bbl manifold (with 2bbl adapter if you wish)? You could easily go with an autolite 2100 with 1.08 or 1.14 Venturi and probably be fine.
- chad
- Registered User
Holley 5200 carb ona truck
papawsfalcons wrote:Chad , do you know if the pinto webber 32/36 is rejetted or stock when used?
viewtopic.php?f=2&t=79610
stoped my search over there on page 4 or 5 w/the above (but just scrolled thru index pages). Not the right thread~
Search w/the Search Function'n carb name...
as stated he tried several diff jets & more...
- bubba22349
- Global Moderator
old28racer wrote:Guy over on the 240/300 site said I might be able to get some real time information on this 2bbl carb. Anyone using one? How is the gas mileage if you stay out of the secondary most of the time?
That 2 X 1 adapter isn't helping you I think if you want better MPG I would just go back to a 1V carb like a Carter YF, a Holley 1940, or the best one for MPG a 1968 Autolite 1101. I ran the Holley 1940 and Autolite with a DuraSpark II ignition on my 1965 F350 300 / 4 speed NP435 / with 4.88 or 5.13 rear gears, 235 75 16 duely and got very good around town economy compared to your combo. Good luck
I am still hunting for a project car to build but with my current low budget it's not looking so good. My Ex- Fleet of Sixes these are all long gone!
1954 Customline 223 3 speed with O/D, 1963 Fairlane project drag car with BB6, 1977 Maverick 250 with C4, 1994 F-150 a 300 with 5 speed.
- old28racer
- Registered User
bubba22349 -- I am just trying to get information on different carbs that will work on a 300".
First I would like to see what best mileage I can get with my current setup (2x1 adapter, 300 log intake & Holley 2300). The current highway mileage at 15.6 is good for a "barn door 1971 f250". If I can't get my city mileage into the12-13 mpg range with the 2300 carb I will try a Edelbrock C intake.
The reason I liked the 5200 was that it has a small primary that I would cruise on 95% of the time. Maybe to small for a stock 300 motor? Do you know bore size of the 5200 primary & the YF/YFA carb?
If the manifold change does not work for the mileage I am looking for I will try the 5200, then the YF/YFA or the Autolite 1101.
- bubba22349
- Global Moderator
The Holley 5200 is based on the Weber 32 / 36 so it also has a primary bore of 32 MM or roughly 1.260 rounded off in inches, the secondary bore is 36 MM or 1.420 inches rounded off. Most of the Ford versions flow 270 CFM measured at 3" HG, Pri. Venturi measures in at 26 MM secondary is 27MM. There is one version said to only flow 235 CFM its Pri. Venturi measures 23 MM this is one to for sure stay away from for your 300 big six.
These carb's were found on the imported Mercury baged Capri in 1971 to 74 2.0l L4 and the V6 engines, plus 1977 to 82 2.3l L4 engines in Pinto's, US made Fox body Capri & Mustangs, Fairmont, Zepher, ect. It was also used on severial GM models with 2.5l L4 engines too. Like the 1973 Vega and the 1977 & 78 Chevy, Pontiac and Olds 2.5l L4 engines.
I don't have a Carter YF off to measure currently so my best guess is that they are around 1.500, 1.625, or maybe even up to 1.750 throdle bore size. Hope that is of some help to you, good luck
- Registered User
1958 F100. 240 4 on the tree. 3.70
I’m currently running a Holley 5200.
My question is..... has anyone installed a sync kit?
It would convert the carb to a standard 2 barrel without the extra cost and work of installing a Motorcraft 2100.
Just wondering if anyone has done this and how did it perform.
- old28racer
- Registered User
bubba22349 --- Thanks for the information on the 5200 & YF/YFA sizes. Do you think a 5200 is to small cfm flow for a stock 300" motor? Remember this is just to improve city mileage.
Blairsville Ed ---- If I may ask what size inline 6 motor are you running the 5200 on?
What kind of gas mileage do you get with your setup?
- bubba22349
- Global Moderator
IN a way it's a bit small since its used on L4 engines that are about half the size of a 300 or 4.9l, but for strictly low speed city driving it could work out ok besides the Carter 1V isn't really all that big eigher. I do think that two or three 5200's might be interesting on a performance street 300. Good luck
- StarDiero75
- Registered User
I know they make 2bbl intakes for the 300 man, I'd just go that route and get a normal autolite 2100 man or keep using the 350cfm. The funnel doesn't do you any good, its not breathing like it should, especially for that big of an engine.
Think about it, minimum size on a 289 or 302 is a 2bbl, why did they not do that stock on the 300? Thats kinda screwy.
- Registered User
StarDiero75 wrote:I know they make 2bbl intakes for the 300 man, I'd just go that route and get a normal autolite 2100 man or keep using the 350cfm. The funnel doesn't do you any good, its not breathing like it should, especially for that big of an engine.
Plus ,the suck pulse of a 302 is about 38 ci. and a 300 is is 50...Makes for a good argument for the two barrel.
66 Mustang Coupe
200 turbo w/lenco 4-spd
Went 9's when 10's was fast.
- chad
- Registered User
Holley 5200 carb
Blairsville Ed wrote:...I’m currently running a Holley 5200.
It would convert the carb to a standard 2 barrel...
Yes, and got assembly of jets, swapped around it still was not right. Didn't mess w/other prts tho.
The owner ('82 or whenever they put the 6 ina Toy heep) had a previous person tie the two together. This meant the 2 were all ways "on". No longer progressive. I kept my eye on it cuz its same displacement as my falcon 250/4L...
Ran fine, plenty power - just stunk, slightly perceptible smoke - too rich (up on jets, dwn - never right). I wasn't gunna mess beyond jets, he was happy. To me they (2v) need to go thru that smooth transition. Put it back the way its designed or get it outta the shop. He went home happy (not me)...
- old28racer
- Registered User
Don't know why any one would tie the progressive together to make direct all on linkage, not how it is to operate. Might as well run a 2100/2150 if that is what he wanted. I think the small primary to cruise around on most of the time would work out well if you can get the right jet combination setup.
Do you know what the stock jetting were?
Is there a separate jet for the Primary & one for the secondary?
- Registered User
1968 F100. 240
It’s a 1968 F100 with a 240. I have put in the Chevy rocker arms, milled the deck to zero, milled the head .030, three angle valve job with some minor porting, efi exhaust, milled the intake and made an adapter plate.
Gas mileage ... 15-16, the same as I got with the Carter YF.
I think I’ll make the parts necessary to sync the Holley 5200. I’m already using the 5200 so it will be a no cost trial. If it performs well, I may convert to a 2100.
I actually got better gas mileage with the engine in stock form with the Carter YF. About 18 mpg.
The carb came with 140 primary barrel main jet, 132 secondary barrel main jet
#50 idle jet on both barrels
- THE FRENCHTOWN FLYER
- VIP Member
- old28racer
- Registered User
I know where you guys are going with the small engines the 5200 was used on. I really think that this carb jetted correctly from a Air Fuel Wideband Gauge would be great for around town 35-45 mph cruising that I do 95% of the time. When you kick the secondary in it will provide the extra acceleration you need. With the throttle kicked in & both Pri/Sec open you will have more cfm air flow than with a YF 1bbl. This would be done on an open 4bbl intake with a 2x4 adapter so it will flow all the air the carb can pull in.
- chad
- Registered User
Holley 5200 carb v Webber 32/36
that's the theory, good luck on the execution.
Try what the brothers have said, get back to us.
We all need more info on these carbs~
- old28racer
- Registered User
Blairsville Ed --- Thanks for the pictures of the 5200 carb mounted. If you have some pictures of the modified log intake while being built I sure would like to see them. Also do you have some closeup of the mechanical choke mount & the throttle mount? They would sure be of help. That is a real clean setup.
- Registered User
heres a few pics
- Registered User
I had to reverse the linkage lever on the carb, which put the pin on top. I then made an extension rod for the stock linkage.
- old28racer
- Registered User
Do the two bolts that hold the adapter you made to the intake manifold seal the adapter to the intake without any other bolts? Do you use some ATV for a sure seal with no vacuum leaks?
Did you have to weld material into the 1bbl hole area as you opened it up to a 2bbl slot? Or was this a grind & open procedure?
Did you make the choke cable bracket? The throttle setup looks easy even though my stock linkage has been changed because I am running a Holley 2300 350 cfm carb currently.
- Registered User
There’s a 3/8 stud on the opposite side with a backing plate on the bottom. I used standard 1/32 gasket material to seal. No additional sealer was needed.
The cutout in the manifold was milled. No welding was needed. The 2 bolt holes are already there, you’ll need to install the threaded inserts. Internal thread is 3/8-16.
The choke mechanism was home made. It’s a copy of a Dorman manual choke kit 55101.
- old28racer
- Registered User
Thanks for the additional information. Do you have any pictures of the intake while you were opening it up that you could post on this tread?
- Registered User
I should have taken some pics but I did not.
There were some pics on the Ford truck blog showing a guy milling the head. That’s where I got the idea from.
I have 2 mounting blocks available if anyone is interested. The one on the left is for a Carter YF, the one in the middle is for the Holley 5200. I currently using the thin one on the right.
- old28racer
- Registered User
Blareville Ed --- Sent you a PM about the 5200 adapter.
- old28racer
- Registered User
Blairsville Ed --- Sent another PM to you on the adapter.
- Registered User
Update:
I made a sync kit for my 5200. I copied the kits that are currently available online.
I think I posted this already, but my opinion of the 5200 is that it will work well if you drive primarily on flat ground without towing or hauling weight. The small primary barrel will give you good economy and drive ability.
It kind of forces you to accelerate slowly since you have to put the pedal down further than the YF to get the same results.
For driving up grades or pulling a boat, I find that the synced up version responds much better, and pulls my pontoon up the ramp better. I think that FTF’s advice on 2 barrels was accurate. He recommends the Motorcraft 2100. I may try one of these in the future.
- old28racer
- Registered User
Blairsville Ed -- Ed, thanks for the reply on the 5200 carb. I do not know what a SYNC Kit is for a 5200, why do I need it? Do you have a picture you can post of what you have? Can you tell me how it operates as per the 5200 carb. Thanks
- Registered User
The sync kit is not necessary, it converts the Holley 5200 to a standard 2 barrel where both barrels open at the same time. I installed the kit to compare the performance under a heavier load.
- chad
- Registered User
Holley 5200 carb
guy brought a Heep in previous mechanic did that to (different method tho). U may have saw my posts.
Re-jeted it some but still off. Went higher jets & lower. I wasn't happy (stunk, very sm amount of haze out the tail pipe) but he wuz so let it go.
",,,Do you know what the stock jetting were?
Is there a separate jet for the Primary & one for the secondary?,,,"
there were 4 as I remember
primary, air, main, idle, also emulsion tubes...?
old28racer wrote: I will be getting a new wideband AF unit next week to see where the carb/motor are right know.
Did you install the AF unit?
- old28racer
- Registered User
Well guys thanks for the replies. I just had surgery on my right leg and can not be at the computer for a few days, will get back to you as soon as I can. Thanks
- chad
- Registered User
Holley 5200 carb
old28racer wrote:Well guys thanks for the replies. I just had surgery on my right leg and can not be at the computer for a few days, will get back to you as soon as I can. Thanks
Good Luck wid it,
Speedy recovery!
- VIP Member
- old28racer
- Registered User
FTF & chad -- Thanks very much for the get well note. This was a procedure to seal up some veins in my right leg. My Dr inserts a micro wire with a camera & injector to seal some veins that have wall damage & are letting blood just flow out to my skin. I had some done two years ago and this is the rest. They use a glue to block the bad section. I had very good results from the first procedure and I am sure this one will be fine also.
pmuller9 --- Yes Paul I did get the AFR gauge in the truck but have only had a few minutes to try it out. I checked my idle screws & they are both set at 1 1/4 turns open. The truck idles & runs great just get bad city mileage. First test run with the AFR unit showed 11.6 at idle in park. At cruise 35-40 mph AFR was14.2, freeway 55-60 mph AFR was 12.6. With the idle screws open 1 1/8 turns the Idle AFR went from 11.6 to 12.8. I tried them at 1 turn open & it leaned out the idle to 15.1. I am going to retest to make sure on the numbers. After I have the idle where I want it I will retest cruise & freeway numbers and get vacuum reading at same time. Maybe this next week.
My current city mileage is a low 8 mpg. My freeway is 15.6 mpg. Freeway mileage is not bad for a F250 barn door but I think I can get my city mileage up to 12 & maybe 17 freeway with some jet changes from 61's down to 59/58 and replace my current 8.5 PV with a 6.5 PV. Mike's carb Service will test the new PV to make sure it is working properly. Thanks Paul
Hey Tom -
Best wishes for further success there. Doesn't sound like a lot of fun, but does appear that your doctor has a handle on it. Be well.
- chad
- Registered User
tunining 4 milage: Holley 5200 carb
funny, mine they just pulled em all out, both legs - urs, they glue shut...?
I'll stick wid PV'n jets, no? aaahahahaaaa
your positive attitude is what takes ur healing so far!
Good to hear it, I'm relieved...
- Registered User
I hope your recovering well. Sounds like you have a good doctor.
- old28racer
- Registered User
J.R. -- chad -- Blairsville Ed ---- Thanks guys for the kind words. Had the procedure on Wed and as of today all seems to be healing well. Will have an Ultra Sound done next Tue to make sure all is sealed. Can't do any work on the truck for a week or so, then I'll get back to it.
- woodbutcher
- VIP Member
Good luck.Have fun.Be safe.
Leo
Otto von Bismarck
Otto von Bismarck
- old28racer
- Registered User
woodbutcher --- Leo, thanks for the good wishes. Love this forum with great people and information.
- Registered User
Since I have had my Holley 5200, I have been puzzled by the idle mixture screw setting. With a proper idle jet installed, the mixture screw needed to be 4 turns out to get a good steady idle. Internet wisdom indicated that a larger idle jet was needed however, the larger jet ran the off idle mixture too rich as measured by an O-2 sensor. Then I noticed a replacement mixture screw available online. I compared it to the screw that I had and I found that my screw had a longer more gradual taper. The replacement screw solved the problem. I’m now at 1-3/8 turns and my off idle mixture is steady. Is was bouncing around before. I’m guessing that 4 turns out with the old screw may have been leaking air around the threads.
- old28racer
- Registered User
Blairsville Ed --- Ed, thanks for posting the information on your idle screw problem, I am keeping all this on file for when I pick up a 5200. I do have a question on your main jet sizes on the 5200. You had posted before that your stock 5200 had 140 primary jets & 132 secondary jets. This seems a little strange that the primary bore is 32mm & secondary 36mm and yet the smaller primary has the larger & the larger secondary has a smaller jet. What's up?
Also do you have the order number for the idle screws that you got on line? Would like to keep it on file for later rebuild.
- chad
- Registered User
Holley 5200 carb
here's who I used:
https://www.greenfieldautospecialists.com
lots of carb parts, I just called then walked in.
Mike's is just the best if U ask me (vids on rebuilds, enuff on-line info to research different model carbs, etc)
https://www.carburetor-parts.com
and fr any 32/36: Redline
http://www.redlineweber.com
( huge rep, yrs of service, prts, etc ) autho Weber-in-USA dealer I think...
- Registered User
Quadrajet parts
They list it as a screw that fits Holley 5200 and Motorcraft 2100 carbs.
I’m doing more jetting this week I’ll post the results.
Also, I noticed that the accelerator pump is set to operate with the slightest throttle movement. Engine vibration alone could cause extra fuel to be injected. I’d suggest that the lever be bent a little to provide a little clearance. There’s a cam on the primary throttle shaft that moves the lever.
- old28racer
- Registered User
Still no answer on the stock Holley 5200 jet question?
If the stock 5200 uses 140 main jets in the primary 32mm barrels & 132 main jets in the secondary 36mm barrels, is this correct? Seams like the sizes are backward?
Is a 140 jet for a 5200 "smaller" than a 132 jet?
Are 5200 jets smaller in flow size as number gets bigger?
Help me out
Help me out
- Registered User
The 140 main and 132 secondary jet is how the carb came to me from an eBay seller.
That could be how the Pinto engine ran best.
Currently, I’m running a 140 main and a 150 secondary. With these jets, I’m running a little rich.
I tried down sizing the idle jets today but it appears that a 50 idle jet on both barrels is correct for my set up.
I ordered 130 and 135 main jets but I received the wrong jets today.
Hopefully, I’ll get the correct jets in a week.
