Woodruff key availability
Phase3
Post #1 by Phase3 » Sat Aug 10, 2019 10:12 pm
Anyone know where i can get 1 or 2 crankshaft keyways and 1 or 2 camshaft keyways? Ive seen some mr. Gasket offset ones but thats it so far. Thanks
1996 f150 turbo 4.9 OBD2 M5OD 4x4 12 lbs on 93
1997 f350 351w cclb
THE FRENCHTOWN FLYER
Re: Woodruff key availability
Post #2 by THE FRENCHTOWN FLYER » Sat Aug 10, 2019 11:21 pm
The best method is to lengthen the crankshaft keyway to accept a Chevy keyway which is roughly twice as long and engages the damper and crank gear much more readily and securely.
Max_Effort
Post #3 by Max_Effort » Sun Aug 11, 2019 11:02 am
Phase3 wrote:Anyone know where i can get 1 or 2 crankshaft keyways and 1 or 2 camshaft keyways? Ive seen some mr. Gasket offset ones but thats it so far. Thanks
I get them from the engine parts distributor I have an account with. Usually in Dura-Bond or Pioneer brand. They come individually or in finishing kits. I buy a finishing kit with every engine kit, it’s inexpensive and makes life easier. If you can’t find them locally, try one of the online engine parts distributors, engine tech, northwestern, falcon global.
If you still strike out, PM me and I can send you some.
sdiesel
Post #4 by sdiesel » Sun Aug 11, 2019 1:51 pm
THE FRENCHTOWN FLYER wrote:The best method is to lengthen the crankshaft keyway to accept a Chevy keyway which is roughly twice as long and engages the damper and crank gear much more readily and securely.
Darn it, much of my ford, is chevrolt already, and here we find anotheruseful upgrade from ford to GM.
OY....
woodbutcher
Post #5 by woodbutcher » Sun Aug 11, 2019 2:39 pm
:hmmm: You can also buy key stock of the needed size and cut it to proper length.IIRC,it comes in 6" or 12" lengths.Any machine shop supply company should be able to supply it with no problem.
One outfit I used to work for purchased it in 3 ft lengths,as the used a great deal of it.Almost forgot.You might also try Fastenal(spelling?).
Good luck.Have fun.Be safe.
Leo
Otto von Bismarck
Phase3
Post #6 by Phase3 » Sun Aug 11, 2019 6:33 pm
Thanks everyone for the replys. So im not sure i can cut the keyway out much bigger as the lower end is already put together on this motor and id imagine that keyway would get milled bigger correct?
Also thanks max for the parts breakdown. It shows the crank woodruff is 3/16 by 1 3/4. When i search for that i find 25 packs of pioneer keyways that show thell fit a 460 or FE crankshaft. I think i have a few 460 cranks laying around i might see if that keyway is the same before ordering or just use one of those.
1997 f350 351w cclb
Post #7 by THE FRENCHTOWN FLYER » Sun Aug 11, 2019 7:22 pm
woodbutcher wrote::hmmm: You can also buy key stock of the needed size and cut it to proper length.IIRC,it comes in 6" or 12" lengths.Any machine shop supply company should be able to supply it with no problem.
Leo
Its a CURVED KEY that fits in a curved scalloped keyway.
woodbutcher
Post #8 by woodbutcher » Mon Aug 12, 2019 11:14 am
:hmmm: Hi FTF.Is that the half round type key?I was thinking square profile.That`s what I get for thinking :bang: :rolflmao: .However,if the square profile is whats needed,the places I mentioned are good places to inquire.
Leo
Otto von Bismarck
68Flareside240
Post #9 by 68Flareside240 » Mon Aug 12, 2019 1:04 pm
Tractor Supply had woodruff keys in several different sizes when I was in there the other day. Not sure if they fit this application, but they have them.
Max_Effort
Post #10 by Max_Effort » Wed Aug 14, 2019 8:50 am
FKF-4 is around $9 online....
There are six kits on hand at my local warehouse.
Phase3
Post #11 by Phase3 » Wed Aug 14, 2019 11:40 am
Max_Effort wrote:FKF-4 is around $9 online....
Good info! I might be missing ine of the cam spacer rings too so i might call around. Otherwise summit 8.99
1997 f350 351w cclb
Phase3
Post #12 by Phase3 » Fri Aug 16, 2019 10:41 am
Just found on rockauto
Another option
1997 f350 351w cclb
BigBlue94
Post #13 by BigBlue94 » Fri Aug 16, 2019 11:28 am
Any machinist type shop will have them. My engine builder did. Woodruff keys are indeed the rounded key. Woodruff keys usually come in "standard" sizes. This is party due to the fact that woodruff key cutters come in certain sizes.
MSCDIRECT.COM has them, but minimum order seems to be 25 pieces.
F-250 Restorer
Post #14 by F-250 Restorer » Fri Aug 16, 2019 8:59 pm
I purchase a small kit from headbolts.com. For $8.95 you get: Engine finishing kit Ford 240 / 300 / 4.9 liter inline six cylinder engines
2 cylinder Head to block Dowels .6745 x .435
2 Cam Thrust Plate Bolts 5/16-18 x 3/4 Cap Screw, Hex Drive
1 Woodruff Key 3/16 x 1-3/4
1 Cam Key 3/16 x 3/4
1 cam snout Spacer 1.516 x 1.255 x .194
1 Oil Galley Plug 1/16-27 x 1/4 Internal Hex Drive
They have many interesting and useful items for these engines, like the cam thrust plate, head to block dowels, h.balancer bolt and washer, etc.
Users browsing this forum: No registered users and 19 guests
