Carb Options For Offy Dual Plane on 240
Red72FarmTruck
Post #1 by Red72FarmTruck » Thu Oct 03, 2019 3:12 pm
So motor should be ready in a few weeks. I've purchased an Offy Dual Plane for my 240. It going to be getting a slightly overstock cam (RV style). I'm looking for suggestions on carbs. I have seen many running bigger 2 barrels to small four barrels. Are there big modifications that have to be made to the linkage when going this route? Anyone have a preference on basic smaller 4 barrel?
MechRick
Re: Carb Options For Offy Dual Plane on 240
Post #2 by MechRick » Thu Oct 03, 2019 6:55 pm
Location matters. I had problems here in Vegas with a Carter 500 cfm four barrel, heat causing fuel to vaporize out of the bowls (heat soak). If you are in a cooler climate they work well though.
Holley 8007 390 cfm is a bolt on and go solution, but they are pricey.
Cheaper route is a vacuum secondary Holley 600, but it may take some tuning on the Offy DP to get it to run right.
You do need to run a non-synchronous (progressive linkage) carb on the DP to take advantage of the smaller runners in the intake (MPG), so most two barrels are out.
Stock cam, aluminum cam gear
guhfluh
Post #3 by guhfluh » Thu Oct 03, 2019 7:07 pm
Anything is going to take some decent reworking of the factory linkage on a 72 to work sideways on a Dual Port manifold. What may work the best is a conversion to cable from a late 70's truck or something from Lokar that might convert the stock linkage.
F-250 Restorer
Post #4 by F-250 Restorer » Fri Oct 04, 2019 8:08 pm
I am in So.Cal and had the same heat issue with a DP and a Summit 600 carb. I now use a Holley, and don't have any heat problems. Just for clarification, I only had the problem during hot summer days.
My truck is a 75. When I installed the DP and 4v carb, I converted to a Locar 48" cable. It was very easy to install.
old28racer
Post #5 by old28racer » Sat Oct 05, 2019 11:27 am
What Holley carb are you using with the DP intake manifold? I am in Southern CA.
Users browsing this forum: No registered users and 10 guests
