F250 300 AFR / Vacuum Reading With Holley 2300 350 cfm Carb
old28racer
Post #1 by old28racer » Fri Oct 04, 2019 10:24 pm
The following information is from my latest road fest with a AFR & Vacuum gauge inside the cab. My truck is a 1971 2WD F250, 300, C4, 3.73 stock fresh rebuilt motor (5,600 miles). Carb is a Holley 2300 350 cfm 2 barrel mounted on a 300 log intake with a 2x1 adapter (very restrictive).
Today I was able to make another road test ( all the same places ) with quality vacuum hose. Before I post numbers let me say that the vacuum reading are very close to the first ones I got back a few months ago.
The AFR & Vacuum reading were taken at the same time. Both idle screws are set at 1 turn open. Idles very smooth at 650-700 rpm.
Idle in gear with motor up to running temp -- ( AFR = 14.7 - 15.2 ) --- ( Vacuum 19" )
35-40 cruise -- ( AFR = 14.6 - 14.8 ) --- ( Vacuum 16" )
55-60 cruise -- ( AFR = 14.2 - 13.9 ) --- ( Vacuum 13" )
WOT in drive, just rolling to 60 mph -- AFR = 11.2 ) --- ( Vacuum -0-" )
I would stand beside the numbers as being accurate. When I change jets I have a new 6.5 PV to replace the 8.5 PV that is in the carb now.
With the cruise and WOT number I feel like I should go from a pair of current 61 jets to a pair of 57 jets for the first change, don't think 59's will make that much difference.
Users browsing this forum: No registered users and 15 guests
