Carb Choice? It's different than the rest, no really!
Broncomike
Post #1 by Broncomike » Fri Jun 26, 2020 6:03 pm
Well, only a little different.
I have a couple of 1.21 2150's and was planning on rebuilding one for my Offy C/HD manifold swap. However, I found an older Holley 2300 in my carb pile and it lists as a 275cfm off a late 60s IH 266 V8. So now I'm not sure which to try? Any thoughts?
THE FRENCHTOWN FLYER
Re: Carb Choice? It's different than the rest, no really!
Post #2 by THE FRENCHTOWN FLYER » Fri Jun 26, 2020 10:20 pm
try them all
cheaper than 18 holes of golf
Post #3 by THE FRENCHTOWN FLYER » Fri Jun 26, 2020 10:21 pm
IMO more fun too
Broncomike
Post #4 by Broncomike » Fri Jun 26, 2020 11:42 pm
Think the 1.21 is too much for a stock engine? They're about 350cfm if i remember right. At 350cfm, I feel like a holley 390cfm 4bbl would deliver comparable power and better mileage?
Post #5 by THE FRENCHTOWN FLYER » Sat Jun 27, 2020 12:12 am
A 350 2V is only equivalent to about 250 cfm 4V rating. It will be fine.
Broncomike
Post #6 by Broncomike » Sat Jun 27, 2020 12:41 am
I think I'll take your advice and just rebuild them both. If nothing else, it'll be a fun experiment. Out of curiosity, have you ever swapped a 2150 to a manual choke? I've got one set up on my carter and like the simplicity.
Post #7 by THE FRENCHTOWN FLYER » Sat Jun 27, 2020 9:10 am
I have used a manual choke. I like them because I live out a ways from anything and generally it is a couple mile highway drive to anything. Once the car is started and on its way I could push the choke all the way in and all is well.
If you have to do a lot of stop-and-go during warm-up an auto choke, properly adjusted, is better as the engine slowly comes up to operating temperature.
old28racer
Post #8 by old28racer » Wed Jul 01, 2020 3:53 pm
You will love rebuilding & working on your 2150, they are the easiest carb to work on that I have ever messed with. Being able to remove the top plate with the carb on the car/truck to make needle/seat & jet changes is a big plus. I think your mileage will be better with the 2150 0ver the early Holley as the 2100/2150 use smaller jets sizes than the Holley (any where from 8-10 sizes smaller). My Holley 2300 350cfm has factory 62 jets & my 2100 has 48's.
