Gml motorsports
I’m at my wits end with this one boys,I have been an engine builder and machinist for ten years
Never had this issue before. I built an engine for a customer of mine it runs great awesome response28 miles to the gallon ! he was happy until it started leaking coolant on the driver side of the block between the head and block . The block was bored .040 decked and the head was gone thru completely all new parts. he probably had 50 mi on it when we noticed the leak so we replaced the head gasket With felpro 7916pt1. Head and block were true still leaked 20 mi later , replaced bolts with studs cut down front passenger stud that contacts water pump and used thread sealer chased bolt holes used appropriate arp lube on fastener still leaks. Took off head Magna flux block and head pressure tested block and head. No crack at all put back together with the studs. And the high track sealer on head and block still leaks. I am so over the project I wish he would of bit on the 302 swap
