So I think I have a issue with my fuel boiling, but am not positive. Yesterday while driving home my 63 ranchero started chugging and stalling out, then it would pick back up, and then do it again. It was worse if I took my foot off the gas, and got better if I disengaged the clutch. I just recently had the transmission out to repair the clutch fork. I have also upgraded the ignition to a MSD coil, pertronix mag p/u in the distributor, and I advanced the timing because the plugs were burning like they it was a little retarded. When the car finally stalled out, it would crank, and when I got out to pop the hood I left the key in the ignition and the resistor wire behind the instruments burned off a good portion of the insulation. After sitting for a few minutes it finally started back up and drove home like normal. I know I am missing the hot air pick up/heat sheild off the exhaust manifold, but I have one living in my shed. I've heard of people having fuel boiling issues with out those installed, so I figured that may have been the cause. Any opinions or thoughts? or am I fubar?
*edit* also, I'm not sure what temp I was running at, my temp gauge is shot. But the coolant is good and at a good level, hoses are ok, and nothing felt or looked like it was overheating.
