I have a rebuilt D8BE 6015 GC block with a D7BE head with a Duraspark II distro and and Autolite 1100 in my wife's 65 Mustang Vert. The 1100 is an SCV carb and I've been told that there would be some issues with this carb and a Duraspark II distro. Some folks on the Mustang forum suggested that I run the vacuum advance to manifold vacuum and plug up the ported vacuum on the carb. I did that. Another member also mentioned about modifying the 1100 but didn't go into detail so I don't know what he meant. Another, a larger carb, eg. one for a 77 Granada or Fairmont but said I'd have to adapt my throttle linkage to the carb and probably have to get a different spacer. Apparently I have an aftermarket spacer between the carb and the intake log someone said. The spacer on the car intake port is the same diameter as the intake log so there is no flow restriction there. If getting a different carb and spacer is an easy fix, do I get a Carter for a Grenada? What about the spacer? The spacer for a Grenada has a number of other ports on it that seem to hook up to anti pollution devices that I don't have, maybe an EGR valve? Eventually I want to go with a Sniper 1100 since this engine seems strong. The guy I bought it from had it rebuilt and it was in a 67 Ranchero before he decided to do a V8 engine and AOD swap.
The pictures are before I re-routed the vacuum advance line to manifold vacuum shared with a T with the C4 Trans vacuum line on the front side of the manifold under the carb. I would appreciate any advice on how to mod the carb to work better with the Duraspark II distro.
