ThinLizzy13
Looking for some guidance from the been there done that crowd. I just finished a DSII install into my 63 F100 with a 223. It runs sooo much better now. Anyway, the problem I have is the throttle linkage to the new carb. I'm assuming I'm going to have to rig up a throttle cable of some sort. Before I attempt to rig something up I thought I'd see if anyone has any guidance or pics of how they rigged up a carter to their 223/215?
Excellent looks like a great solution, there's always more than one way make things work. Vacuum leaks caused by a loose throdle shaft in the carb's base plate are a common problem and should be expected when working on these old carb's having decades of use. They usally only wear on the one side because of the throttle linkage leverage pushing or pulling the throdle arm and shaft turning against the carb base plate hole/bore plus the return spring pulling it back shut again. Had to fix or else replace many carb's when pressed for time over the years. Back about 6 months ago FTF (French Town Flyer) over on the Big Six forum was working on fixing these same problems on his supply of Autolite 2100 and Motorcraft 2150 2V carb's that he uses on his 300 powered race cars. He located all the parts and tools to repair them and then went step by step on the repair process in his posts, you can read about how he did it in the below link. This technique and probally even the same parts could work on your Autolite 1V carb's. If I remember correctly the throdle shaft are same standard size you wold need to measure your throdle shaft OD to verify this. Best of luck.
