The heat shield is bolted to the starter cover that was hammered lower to clear the #6 header pipe.
The starter would not install before the cover was hammered down.
The # 6 pipe has been hammered to give clearance also. The header pipe is tough stuff to dimple without out heating it red hot.
I only have a propane torch. The cover along with the shield can be removed from the starter with the header on. (this used parts starter has the bendix lever spring removed so the cover heat shield may be harder to remove on a starter with the spring in it.)
