67drewstang
I ordered, received, and installed the Classic Inlines Duraspark II dizzy kit on my 1967 Mustang convertible with 200 ci I-6 and just to cut to the chase; it is as if someone put an additional engine under my hood.
Turns out, my stock distributor has never worked correctly. Mechanic after mechanic has mistakenly blamed the carburetor for running in an over-lean condition. I have replaced the exhaust manifold four times over the 37 years that I have owned the car. It routinely dieseled on shut down. It always ran hot. It has always barely maintained highway speed, and then only when only one passenger was carried.
Now, with the Duraspark II and proper advance, I am able to spin the tires at intersections routinely. I can drive 75-80 mph on the interstate. I can even accelerate, even when carrying passengers, at the speed of traffic or better. And, obtw, it runs always in the lower portion of the temp gauge. I can even see the temp drop down when the thermostat turns on.
If I were to do this all again, I would not put a penny in the car before replacing the Load-O-Matic distributor. This is the single best mod I've ever done to any car.
