Engine ID help.
armypilot
Subscriber
I inherited a 1966 Bronco that has been sitting since 1995. It appears to have a reman engine in it that has never been ran. I had bought a new carburetor, but it doesn’t fit the holes on the intake are too far apart and they’re at an angle. Upon further inspection, the block has a date code of 1968 and the intake has a date code of 1970. I am trying to find a carb but I don’t know what engine I have.
Provide the code for the head and the block or use this from the Tech Archive.
Small Six Casting Numbers​
  • The first two digits were the production year, the second two digits were the model.
  • The first digit (always a letter) was for the decade - C=60's - D=70's - E=80's
  • The second digit (always a number), was the production year.
For example: C3 is 1963 - C6 is 1966 - D7 is 1977 - E0 is 1980 - E2 is 1982
YearSizeBlockHeadCrankNotes
60-64144ci????????????
60-64170ciC0DE-C4DE????????
1965200ciC5DE-HC5DE-B, C6DE-A1H4 Bolt Bell
66-67200ciC6DE-AC6DE-A, C7DE-A1H6 Bolt Bell
68-69200ciC8DE-8C6DE-A / C8DE-B
C9DE-R / C9DE-M
1H
6 Bolt Bell
70-74200ci????????????6 Bolt Bell
75-80200ciD8BE-GE
E1BE-FA
D5DE-BA1H6 Bolt Bell
81-83200ciE1BE-BBE0BE-BB
E1BE-CC
3HBig Bell
69-74250ciC9DE-B
D2DE-AA
C9OE-M2HSBF Bell
75-80250ciD8BE-JA / 8DE-CC
D7DE-CA /D6DE-CA
D5DE-AA
E0BE-BB / D5DE-BA
D7BE-AB / D3BE-AA
D8BE-BA / C9OE-M
3HASBF Bell
These are good to have but the Falcon Performance Handbook is hard to find currently.
www.vintageinlines.com
Ford Inline Six: How to Rebuild and Modify | Vintage Inlines
Covering Ford’s small 6-cylinder engine made famous in Falcons, Comets, Mustangs, and many other models from the 1960s and 1970s, this book has everything you need to know from step-by-step rebuilding instructions to performance parts that will set you apart from the rest of the crowd. If this...
The Ford Falcon SIX Cylinder PERFORMANCE HANDBOOK | Vintage Inlines
The Ford Falcon SIX Cylinder Performance Handbook has 107 pages of History, Facts, and Information to help you get more power out of your small Ford SIX. This engine was used in Falcons, Mustangs, Fairlaines, and Comets in the 60’s. It was the FoMoCo workhorse in Mavericks, Granadas, and...
