need some opinions. we've got a 66 mustang, 200 ci. odometer says 74K miles which I've assumed is at least 174K miles. it drives ok, still messing with the choke tho.the car's had some mild body damage, the interior, while old and discolored isn't worn thru. seat belts also look pretty good. I know who's owned it for about the last 12 years, at one point it was really a little old lady. ball joints and tie rods ends had to be replaced recently, also put in a FR 16:1 steering box.
we're working through upgrades to the carb, ignition and exhaust. waiting for a pony carbs 1101 -V, spendy but mighty intriguing. then a 69 distributor with a pertronix ignitor system. needs new rocker arm assembly, the rocker arms will not move laterally at all and oil only drips from rockers for cyl 4,5,6. did a compression check and got 135# for #1 and #2 and 150# to 155# for 3 - 6. didn't squirt oil into the cylinders to see what that did for compression. top end isn't gunked up, the inside of the valve cover had a mild amount of cooked on stuff but no sludge. vacuum flutters slightly at 18#. valve cover has been repainted (didn't quite match).
the valve springs are clearly green so I'm thinking either this had been rebuilt at some point in the past or, is it possible that those are original miles?
I had been planning on tearing the engine down in the winter but now may hold off and do the body work. of course a rebuild would mean decking the block, high compression pistons, balancing, boring. moderate head work, porting, bigger valves, 3 angle valve job, maybe mods to the intake log or .... if money fell in my lap, the new classicinlines head....I can't help myself.
so here's the questions, in order of priority. should I be concerned with a 20# difference in compression for now? Is there any reason why #1 and #2 would be lower than the others (I mean like a design reason, not bad valves etc. I know the other reasons compression can be low)
would the original springs have been green in color? thanks for helping me prioritize our work. we're just finishing up a 3 year 65 barracuda project that was supposed to be 6 months and $4K. it's 3 years and $12K now... but it's totaly redone, ground up with a race prepped drive train. and yes I do always look for the next improvement I can make in anything, it's a character flaw... ;<)
