I know of one of our site members "Wanye Clark" that did a Holley Sniper 2300 install on both the stock log head and then transfered the 2300 EFI over onto his V. I. Aluminum head. I would recommend that you read about both of those installs to see what he learned about setting up the Sniper 2300. Here is one of his posts on it. You might also try to contact him about the info on his install. Good luck on your project car. Edited
[Quote by Wayne Clark] "
Hi all. I know this post is an old one but thought I would reply any way.
I have a 67 Mustang vert 200/c4. At this time I'm running a 2300 Holley Sniper on a small log head thru a 1x2 adaptor. I have a 3 into 1 split header with 2 1/4" dual exhaust. It has a msd 6al ign box ( not useing it for timing control) & a dura spark dist.i put a Holley intank EFI fuel pump on it( the supplied fuel pump in the kit is a pain in the a##)
The Sniper install,setup & startup was extremelly easy, except all the extra stuff that it took to make everything fit & work. Initially I installed the supplied o2 bung on a 67 stock small downpipe, that was a mistake. When the header & duals went on I welded a bung in one pipe. Worked great until the supplied header gasket burnt thru in the # 3 & 4 port . Installed a remflex header gasket from summit, its held up ok so far.
To summarize the car starts instantly, idles smooth ,has more power overall. With each of the exhaust leaks the sniper went absolutley stupid, dumping gas in the motor. With each fix of the leaks it self learns again.
With everything else I have going on since I retired I don't stay on it or drive it as much as I would like too. At some point during the stupid phases when it was dumping all that gas ,it started haveing periods of shooting gas out of some of the many holes around the butterflys, for the most part that has stopped. I have tried calling the Holley Tech line to talk to somebody about that but have found it impossible to get anyone on the phone for months. Looks like they would hire somebody to help the 1 guy they appear to have.
So I would say to some one who has a 6 cyl Ford ( especially a small six) if you want the most bang for your buck upgrade your ignition system & put a sniper on it.(or possibly another brand) Weld the 02 bung in . I can't speak about the new one barrel they have but the 2 barrel is great on the small six even if everything else is stock. Follow all their install instructions as they say & its great."
The Money Pit Holley 2300 Sniper EFI install on the stock log head.
https://fordsix.com/threads/couple-...-pit-my-67-vert-200-6-with-2300-sniper.81745/
This is a link to his V. I. Aluminum head install that he did later.
https://fordsix.com/threads/classic-inline-head-install.82267/#post-645238
