ozconv
I have the following new engine build and have been trying to tune it.
-200 six, essentially stock short block rebuild but with ARP fasteners, 0 decked, double roller timing set, and H264/274 cam with 112 lobe center, advanced 4 degrees.
-Rebuilt OZ-250 head and intake, ported with 1.8" back-cut intake valves and 1.5" exhaust valves, 3 angle valve job, 302 valve springs.
-1.6:1 Adjustable roller tip rockers.
-Classic Inlines header with 2" dual exhaust and Flowmaster 40s
-Post 68 Pre DS1 dizzy with mechanical and vacuum advance, Pertronix Igniter II, Flame Thrower III coil, Pertronix Wires with 0.045" plug gap.
-Rebuilt 1.02 245cfm Autolite 2100 with manual choke, 48F jets.
-0.053" compressed head gasket with 6.5CC stock dished pistons for CR of approximately 9.3:1.
-stock C4 automatic
-7.25" rear end with 3.2:1 ratio.
I have driven the car approximately 20 miles so far (city and highway). In order to keep it from stalling in gear and being driveable at all, I have had to do the following:
1. 0.040" holes drilled in the throttle plates. Engine does not seem to run rich now and will stay running in park down to approximately 500 rpm although the idle is very rough. At this rpm, my base timing with the vacuum advance plugged is 25 degrees BTDC (using dial back timing lite and guestimating since the idle is rough and the timing mark is jumping around). Idle mixture screws still don't seem to have much effect at all on vacuum and rpm but I think a little more than before the throttle plates were drilled. Car will stall when one idle screw is turned all the way in though.
2. To keep it from stalling when in drive, I have to increase the idle rpm to approximately 1200-1500 rpm and use manifold vacuum to increase the timing at idle. At this point the timing is about 55 degrees (in park). The car hasn't overheated yet and the plugs look good, however, the engine seems to hit a wall at about 50mph and would not accelerate well when entering the free way.
3. I have checked my mechanical advance with the vacuum advance plugged and got the following measurements:
500 rpm 25 degrees
1000 rpm 37 degrees
1500 rpm 37 degrees
2000 rpm 42 degrees
2500 rpm 42 degrees
I have swapped the reluctor on the dizzy to limit the mechanical advance to 20 degrees instead of 30 and have verified That the balancer is reading true TDC. If I back the base timing to anything less than 25 degrees and do not use manifold vacuum advance, the car stalls in gear. I don't know the rpm in drive but I would guess around 800 rpm?? I am thinking that the mechanical advance is too aggressive. I have replaced the smaller spring with one of the Mr. gasket 925 springs and bent the post for the heavier spring inward though I am thinking that it is bent in too far. 20 degrees of vacuum advance also seems like a lot but again that is what it takes to get it to stay running in drive. So far I haven't gone past about half throttle for fear of damaging the engine. Also at about half throttle the exhaust goes from sounding great to kind of a resonant buzzing. I was under the impression from the CI tech articles that this cam was not too agressive for an automatic and that the vacuum would be higher though 14 inches at 800 feet above sea level is the best I can get and in gear is around 11 inches.
Any thoughts or suggestions would be appreciated.
-stock C4 automatic
500 rpm 25 degrees
1000 rpm 37 degrees
1500 rpm 37 degrees
2000 rpm 42 degrees
2500 rpm 42 degrees
