I plan to upgrade a 6 cyl dual (centrifugal/vacuum) distributor with a Pertronix igniter. The correct Igniter is the 1261. I know the 1266 is for a Load A Matic .
Is anyone aware or any installation or "fit" issues for the 1261 in the 68+ 6 disty?
Can you provide a picture of the installed Igniter?
I am also planning to use the 3.0 ohm Flamethrower Pertronix coil and use a relay to provide 12 volts to the coil. Thanks
