I need the forums help and expertise, once again!
It is an original steel shim head gasket (D7BE that I got from "powerband") that I will reuse for my 200 build with original log head.
The forum already suggested I should use some sort of sealant to make sure the head gasket will not leak.
I have 3 options at hand at the moment:
1) Aviation Form-A-Gasket to be applied with a brush
2) Hylomar spray can
3) Copper Spray-A-Gasket spray can
The main goal is to make an efficient seal but make it also possible to remove the head without damaging the gasket in the future to put a new cam in the block.
I heard that option 1) is kind of like a glue, and that 3) may also be so sticky that the gasket could be damaged when the head is pulled again. Anyone experienced the same?
Also I read spray application is prefered as it gives a more even coating?
What would you suggest?
PS: I know the block deck and cylinder head surface roughness as well as flatness are important. For the poll please just assume that both surfaces have adequate surface Ra, and are clean and sufficiently flat. Thank you!
