Hello all,
As you can see I'm new to this forum. I'm very happy I stumbled upon this as I'm a huge fan of Ford sixes. I have had great experiences with the one in my 368,000 mile truck that I continue to use with minimal maintenance, and some day I'd like to build a new one for it. I find the idle of a hot straight six a lot more pleasing than the all-too-familiar idle of a V8, and a powerful I6 is a lot more unique than another small block V8. I find everything about these motors interesting.
Anyways, the reason I'm posting is I could really use some help. My girlfriend recently bought a 1967 Mustang that's a bit of a rusted-out beater, and I'm trying to get it road-ready for her. I've done a whole lot of work on it and we're coming to a point where it's almost driveable. I only need to replace the exhaust, change out the oil in the differential, flush any gunk out of the motor, and fix this idling issue (which I'm assuming has to do with the carburetor), and the car will be driveable for her. Unfortunately I'm a bodyman first and a mechanic second, and I've never dealt with a carburetor in great extent. I rebuilt the one on my motorcycle, and I've taken apart and adjusted the one on my truck and on this car, but I can't seem to grasp how to adjust it correctly despite having read how several times. I just can't get the car running how everyone is saying it should when I do what they tell me to.
Now, I'm assuming I screwed (pun unintended) up something while messing with the idle speeds and mixture. The car will start up reasonably easily even in the low-teens temperature we're experiencing, and it'll idle pretty good, but then when the engine starts to warm up it'll stall out. I can keep it running a little longer by massaging the gas pedal a little bit, but eventually it'll die. My father says he can smell that it's running rich, but I don't know.
I've put a Pertronix II into this and I have 12v getting to the coil. This car is extremely beat and with 88,000 original miles on it, it could definitely use a rebuilt engine, but while compression is a little low, it's even throughout all cylinders and I have in the past gotten the car to run impressively smoothly, and I have taken it for a drive several times. However it's a crapshoot as I don't have enough experience with carbs to be able to read what the engine's doing and know how to remedy it.
The carb was recently rebuilt by her father, but he seems to break things more often than fix them and I have found myself several times fixing his mistakes on both this car and her mother's car. Regardless of that, I believe this time he didn't mess anything up with the carburetor as I had the car running smoothly some time ago. I believe this was caused by my messing around with the adjustments trying to fix another issue I was having with the car.
Anyways, I'd REALLY appreciate it if someone (or several of you, the more input the better!) could assist me in fixing this problem. Thank you!
EDIT: It is an Autolite 1100, by the way.
